- Robot JavaScript SDK
- Sobre o SDK de JavaScript do Robô
- Etapas de configuração
- Campos de configurações
Settings class fields for the Robot JavaScript SDK browser add-on: port number, poll interval, telemetry toggle, and application origin configuration.
Configurações do SDK
A propriedade Configurações do SDK de JavaScript do Robô permite que você personalize e melhore seu controle sobre a configuração do add-on do navegador.
class Settings {
portNumber: number;
pollTimeInterval: number;
disableTelemetry: boolean;
appOrigin: string;
class Settings {
portNumber: number;
appOrigin: string;
| Atributo | Description |
portNumber | Lets you configure custom ports on which the back-end services run on. The default port number is 2323. Only available for Enterprise installations. |
pollTimeInterval | Lets you specify the time in milliseconds in which the Robot JavaScript SDK keeps track of a process execution from a web page. The default value is 250 milliseconds. This value determines the polling frequency from the web browser |
disableTelemetry | Lets you disable the telemetry flag. The default value is false. |
appOrigin | Lets you specify the application which uses the SDK. The default value is picked up from the window.location.origin class. |
const robot = UiPathRobot.init();
robot.settings.portNumber = 1234;
robot.settings.pollTimeInterval = 1000;
robot.settings.disableTelemetry = true;
robot.settings.appOrigin = 'MyApp';
Configurações de Add-on
Add-on settings are configured in the uipath.config file in the %ProgramFiles%\UiPath\Studio folder.
The configuration file must contain the following:
<robotJsSettings>
<add key="ListenerPort" value="2323" />
<add key="TokenExpiryInDays" value="30" />
</robotJsSettings>
<robotJsSettings>
</robotJsSettings>
ListenerPort | The UiPath.RobotJS.ServiceHost.exe starts a HttpListener on the configured port and contains the information about other local listeners from the active user session on that system. The port value must match the one configured in the SDK Settings. |
TokenExpiryInDays | Qualquer solicitação proveniente de um novo domínio precisa ter consentimento do usuário para permitir o acesso do UiPath Robots a partir de um aplicativo web. Esses consentimentos são válidos para o referido número de dias mencionados nesta configuração. |
Sobreposição Padrão
It is possible to customize the consent screen displayed when a request is raised from a new domain. Two screens are delivered with the Robot JavaScript SDK:
Prompt de Consentimento
A sobreposição consent-prompt é exibida quando uma solicitação de acesso ao UiPath Assistant é criada por um novo domínio.
Componentes Ausentes
A sobreposição missing-components é exibida quando o add-on exigido não está presente na máquina local.
Overlay messages can be configured as shown in the following example.
// Consent code will be written to the console instead of showing default overlay
// Error logged to console when required components are missing insread of showing
// default error overlay
robot.on('consent-prompt', function(consentCode){ console.log(consentCode) });
robot.on('missing-components', function(){ console.log('Missing components') });
