# Logging troubleshooting
> Solutions for Robot logging issues, including duplicate log entries caused by a corrupted LiteDB database file.
## Duplicate execution logs
### Description
On rare occasions, duplicate log entries would be written to the LiteDB local database, leading to an excessive amount of disk space taken by the log database. As a result, Orchestrator would also receive multiple duplicate log entries. Since the Robot could not write logs inside the database file, repeated attempts were made, without marking each attempt as sent.
### Potential issue
The LiteDB database file becomes corrupt, making the Robot unable to perform read and write operations on the file.
### Solution
If the LiteDB file becomes corrupt, restart the Robot Service. This creates a backup and generates a new file, to prevent the database from becoming corrupt again.
## No execution logs
### Description
Orchestrator does not display any execution logs, even though processes run as expected.
### Potential issue
A corrupted LiteDB file may prevent the Robot from processing execution logs. When a corruption is detected, the Robot halts log processing, and no new logs appear in Orchestrator.
### Solution
Check the [`Robot.log` file](https://docs.uipath.com/robot/standalone/2024.10/admin-guide/understanding-robot-logs) for the "Logging database abandoned." message, which indicates a corrupted LiteDB file.
If a corrupt LiteDB file exists, restart the Robot Service. This creates a backup and generates a new file, to prevent the database from becoming corrupt again.
