# Package Signature Verification
> **Package Signature** is a method through which NuGet Packages prove that they come from trusted sources. A package is signed by using a certificate to validate the identity of a signer. When the deployment is set to check the Package Signature Verification, UiPath validates against the information available in the `NuGet.config` file to find the requested certificate in order to ensure consumed packages are coming from an allowed author or repository.
For an in-depth overview of how Package Signature Verification works, make sure to read through the specifics in [this section](https://docs.microsoft.com/en-us/nuget/reference/nuget-config-file#trustedsigners-section) of the Microsoft guide about [NuGet.config](https://docs.microsoft.com/en-us/nuget/reference/nuget-config-file) file.
## Configuring Package Signature Verification
### Validation modes
* `accept` - Allows for unsigned packages to be installed.
* `require` - For a package to be installed, its signing details have to match the ones from the `trustedSigners` section of `NuGet.config`.
### Enforcing the Use of Signed Packages
To enforce the use of signed packages, the `signatureValidationMode` parameter in the `Nuget.config` file must be set to `require`. The file is located at `%ProgramFiles%\UiPath\Studio`. You can do this in one of two ways:
* During installation, by installing from the [command line](https://docs.uipath.com/installation-and-upgrade/v2022.4/docs/studio-command-line-parameters) with the option `ENFORCE_SIGNED_EXECUTION=1`.
  For example, the following command installs Studio, a Robot as a Windows service, and enforces the usage of signed packaged in your UiPath environment:
  UiPathStudio.msi ADDLOCAL=DesktopFeature,Studio,Robot,RegisterService ENFORCE_SIGNED_EXECUTION=1
* After installation, by manually editing the `NuGet.config` file.
  If you set the parameter after installation, the changes take effect after you:
  1. Restart the Robot Service.
  2. Remove all existing .NuGet packages from `%ProgramFiles%\UiPath\Studio\Packages` and `%userprofile%\.nuget\packages`.
  3. Restart Studio/Assistant.
## Adding Trusted Sources
To download, install, and run packages signed with a certain certificate, add the required certificate as a trusted source.
For this, modify the `NuGet.config` file in the installation folder, in the `<trustedSigners>` section.
:::note
Read more on how to [add or Remove Activities Feeds](about-the-activities-feeds.md#add-or-remove-activities-feeds).
### Adding UiPath as a trusted signer
Open the `NuGet.config` file from the Install Folder and add the following values:
<config>
     <add key="signatureValidationMode" value="require" />
</config>
<trustedSigners>
   <author name="UiPath">
      <certificate fingerprint="D179174EBC1E180D656BFB15BE369DEA8A17C178230FAC7771BF5446940C290C" hashAlgorithm="SHA256" allowUntrustedRoot="false"/>
      <certificate fingerprint="ABD1E1BB749DDC96B46A1DBD91B93A2D8B3B5572D1E20A52F6165ED96FC117E0" hashAlgorithm="SHA256" allowUntrustedRoot="false" />
   </author>
   <repository name="UiPathRepository" serviceIndex="https://gallery.uipath.com/api/v3/index.json">
      <certificate fingerprint="D179174EBC1E180D656BFB15BE369DEA8A17C178230FAC7771BF5446940C290C" hashAlgorithm="SHA256" allowUntrustedRoot="false" />
   </repository>
</trustedSigners>
### Adding a Trusted Author
To add a trusted author, you need to open the `NuGet.config` file located at `%ProgramFiles%\UiPath\Studio\NuGet.config`. Then, provide the `certificatefingerprint` and `hashAlgorithm` as per the example above. Check this [page](https://docs.microsoft.com/en-us/nuget/consume-packages/installing-signed-packages) to get more information about the certificate fingerprint.
### Adding a Trusted Repository
Adding a trusted repository is done roughly the same as adding an author, with the difference that the `serviceIndex` must also be added.
Below is an example of a trusted repository added to the `NuGet.config` file:
<trustedSigners>
<repository name="UiPath Repository" serviceIndex="https://uipath.repository">
<certificate fingerprint="1234512345123451234512345123123123123123123123123123112312312E5" hashAlgorithm="SHA256" allowUntrustedRoot="true" />
</repository>
</trustedSigners>
### Adding Trusted Owners
A repository may have multiple author-signed packages. In this case, the `<owners>` tag can be used for allowing only packages signed by trusted authors to be installed.
Add the trusted authors between the `<owners>` tags, as in the example below:
<trustedSigners>
<owners>Author1;Author2</owners>
</repository>
</trustedSigners>
### V2021.2 Behavior
Starting with the v2021.2 release, the following settings for Package Signature Verification are no longer populated in the `Nuget.config` file at install:
* `signatureValidationMode` parameter is no longer populated in the `Nuget.config` file at install
* UiPath<sup>®</sup> is no longer populated in the `Nuget.config` file at install as both repository and author in the `trustedSigners` tag.
#### Impact:
* If Package Signature Verification is used, all trusted signers, **including UiPath<sup>®</sup>**, must be added manually in the `NuGet.config` file.
* If Package Signature Verification is not used, the `trustedSigners` tag should not be present in the `NuGet.config` file.
* If the `NuGet.org` feed is used, it needs to be added for both accept and require modes as NuGet announces the whole repository as signed.
To resolve the above, you need to [add UiPath<sup>®</sup> as a trusted signer](package-signature-verification.md).
