# 2021.10.2
> 2021.10.2 release notes for Process Mining in standalone.
**Release date: June 1st, 2022**
This page provides more information about the newly released functionality, improvements, and bug fixes in **UiPath Process Mining 2021.10.2**.
:::note
Support for **UiPath Process Mining 2021.10** is extended by 6 months until April 2025. See also [Product lifecycle](https://docs.uipath.com/overview/other/latest/overview/product-lifecycle).
## Platform
### Option to add a non-production banners for non-production licenses
The new Server Setting `UseNonProductionBanner` can be used to add a banner next to the page title to indicate when a non-production license is in effect. This can be used for development or acceptance setups, to separate them from the production environment. See the illustration below for an example.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-docs-image-56389-2c1061ce-d51b10a9.webp)
### Option to export to `CSV` for smaller exports
When exporting a table or graph, it is now possible to select either `Excel` or `CSV` as the output format for data. The `Excel` option is only enabled for smaller data selections.
### Dates printed in `Excel` or `CSV` exports
The export date (the date when the file was actually exported) and the dataset creation date are now printed in `Excel` and `CSV` exports.
## Improvements
* Next to `targetId`, `userName` is now added to the simplify Active Directory audit logs.
* A new table option is now available that enables to change the way filters behave in specific cases.
* File encoding now also works for `mvscript: Multifile` connections. Either `UTF8` (default) or `LATIN-1` encoding is used in the files.
## Other
* The new Server Setting `ShowExportApplicationStructure` can be enabled only for use cases that require a full Application structure export. In this case, the **Application structure** option is added to the chart **Export** menu.
## Fixed bugs
* In some cases, an app with no visible dashboards could not be opened. This is now fixed.
