# My notifications
> Manage personal notification preferences for Process Mining on Automation Suite using the My Notification view in the Notifications settings page.
You can manage your notifications using the **My Notification** view from the **Notifications** settings page. Visit [Notifications settings](https://docs.uipath.com/automation-cloud/automation-cloud/latest/admin-guide/exploring-the-user-interface#notifications-settings-page) to learn more.
Learn about the experience of working with your notifications, by reading about how to manage them in the **Notifications** panel, and about the notification events you can subscribe to.
## Viewing and accessing notifications
You can access notifications through the **Notifications** panel only.
To access the **Notifications** panel, go to the top navigation bar and select the bell ![Bell icon](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-bell-icon-bell_icon_notifications_panel-6428c360-3f0d71bb.png) icon. The **Notifications** panel displays notifications ordered by date, in descending order. The **Notifications** panel displays notifications from newest to oldest.
To access a specific notification, select the desired notification frame.
### Filtering notifications
While you're in the **Notifications** panel, you can further filter the notifications, so you can view certain notifications first. To filter the notifications that you receive in the **Notifications** panel:
1. Open the **Notifications** panel.
2. Select the **Service** dropdown and then select the service for which you want to view notifications.
3. Select the **Severity** dropdown and then select the severity of the notifications that you want to view.
## Viewing and accessing email notifications
When an event that you are subscribed to takes place, an email notification is generated and sent to the email address that you used to create your Automation Suite account.
With email notifications you can perform the following actions:
* Read general information about the event that took place.
* Navigate to the corresponding service and tenant where the event took place.
## Displaying only unread notifications
To display unread notifications, select the **Unread only** checkbox in the **Notifications** panel.
## Marking a notification as read or unread
To mark a notification as read:
* In the **Notifications** panel, locate the notification you want to mark as read.
* Select the **Mark as read** icon at the top right of the notification.
To mark a notification as unread:
* In the **Notifications** panel, locate the notification you want to mark as unread. The **Mark as unread** icon becomes visible at the top right of the notification.
* Select the **Mark as unread** icon to mark the notification as unread.
## Marking all notifications as read
To mark all notifications as read:
* In the **Notifications** panel, select **More Action on All Notifications** at the bottom of the **Notifications panel** and then select **Mark all as read**.
## Clearing all notifications
To clear all notifications from the Notifications panel:
* In the **Notifications panel**, select **More Action on All Notifications** at the bottom of the **Notifications panel** and then select **Clear all**.
## Deleting notifications
You can delete notifications individually. To delete a notification:
1. Go to a notification from the **Notifications** panel and select **Action on Notification**!['Action on notification' image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-action-on-notification-image-vertical_ellipsis_notifications_panel_icon-b61e013c-dc721b6b.png).
2. Select **Delete**.
Selecting **Delete** permanently deletes a notification.
## Subscribing to events
You can subscribe to certain events to receive notifications about them. Subscribe to events in the **Notifications** settings page. Visit to learn more.
:::note
The **Automation Cloud** column is visible for services with in-app notifications enabled. The **Email** column is visible for services with email notifications enabled.
**Subscribing to an event:**
1. Go to the **Notifications** settings page.
2. Go to a service tab and then go to the **Automation Cloud** or **Email** column.
3. Select the checkbox that is inline with the event that you want to subscribe to.
If you want to receive both in-app and email notifications on an event, then select both checkboxes under **Automation Cloud** and **Email** column.
### Subscribing to all events
3. Select the **Automation Cloud** or **Email** checkbox to subscribe to notifications on all events.
### Severity
You can also choose to subscribe to events based on their severity.
#### Subscribing to events based on severity
1. On the **Notifications** settings page, select the **Severity** option button.
2. Select the checkbox that is inline with the severity of the events that you want to subscribe to.
   :::note
   This automatically selects the events related to the selected severity category or categories.
## Unsubscribing from events
To stop receiving notifications, you can unsubscribe from certain events. You can unsubscribe from events from the **Notifications** panel or from the **Notifications** settings page.
:::note
**Unsubscribing from the Notifications panel**:
1. Access the **Notifications** panel.
2. Go to a notification and select the **Action on Notification**![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-action-on-notification-image-vertical_ellipsis_notifications_panel_icon-b61e013c-dc721b6b.png) menu.
3. Select **Unsubscribe from &lt;event&gt;.**
### Unsubscribing from the Notification settings page
1. Go to the **Notification** settings page.
2. Go to a service tab and then go to the **Automation Cloud** column.
3. Deselect the checkbox that is inline with the event that you want to unsubscribe from. If you want to unsubscribe from both in-app and email notifications for an event, then deselect both checkboxes under **Automation Cloud** and **Email**.
### Unsubscribing from all events
2. Go to a service tab and then go to the **AutomationCloud** or **Email** column.
3. Deselect the **Automation Cloud** or **Email** checkbox to unsubscribe from notifications about all events.
   :::warning
   Unsubscribing from all the events of a service, via both **Automation Cloud** and **Email**, generates the following warning: "You’re not subscribed to receive any notifications from this service."
The **Restore default subscriptions** option restores the default subscriptions for notifications received both on **Automation Cloud** and **Email**.
