# KPI trends lists
> KPI trend lists display a graphical representation of main process KPIs on a dashboard, enabling users to drill into details for any listed metric.
## Introduction
KPI trend lists can be used to create a dashboard with a graphical representation of the main KPIs of the process that gives insight into the overall process performance. The following illustration shows an example of a KPI trends list.
![KPI list example](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-kpi-list-example-14569-6e8d1547-5e9e5a35.webp)
The **View details** button on a KPI trends list enables the user to go to the related dashboard for further analysis.
## Properties
You can edit the properties of a bar chart in the **Edit KPI list** panel.
You can select different metrics for which you want to display a KPI charts. For each KPI chart you must select the field that is displayed on the X-axis. Furthermore, you can select the dashboard to which the **View details** button should be linked.
The following table describes the properties of the **KPI list**.
 <colgroup>
  <col/>
  <col/>
 </colgroup>
     Element
     Tooltip
    Text box that enables you add a text that will be displayed as tooltip when the user hovers the mouse over the chart title in the published process app.
    Metrics
     List of metrics to be displayed in the KPI list.  Use the Add metric option to select one or more metrics.  Tip:  You can drag and drop the metrics in the list to arrange the metrics as desired.
     Select KPI chart
     Drop-down list that enables you to select the KPI chart for which you want to define the properties.
     Format X-axis
     List box that enables you to select the field displayed on the chart.  The Format X-axis is a mandatory property. Note:  You can select the new Timeframe filter as a field for the x-axis of a line chart or a KPI chart. When a business user selects a different timeframe the chart will change accordingly.
     Link to dashboard
     Drop-down list that enables you to select the dashboard that should be opened when the user clicks on View details .  If you do not select a related dashboard, the View details button is disabled.
