# Test Sets
> Create and manage test sets grouping individual test cases for execution
## Overview
In this topic, you can learn how to manage your test sets. A test set represents a grouping of a number of individual test cases, serving particular purposes (e.g. full regressions, smoke tests, etc) across any number of projects.
## Create Test Set
Create a test set to prepare for test execution.
1. Log in to Orchestrator.
2. Open your folder.
3. Navigate to **Testing** &gt; **Test Sets**.
4. Select **Add test set**.
5. Configure the following:
   * **Name**: Enter a name for your test set.
   * **Description**: Enter an optional description.
   * **User**: Select the user from the dropdown list that is assigned to that specific folder. The default is set to **Any User**.
6. Enable coverage calculator to view which activities have been covered during the execution. To analyze the activity coverage for your test results, see [Test execution coverage](https://docs.uipath.com/orchestrator/automation-suite/2024.10/user-guide/test-executions#test-executions).
   To analyze your activity coverage in the Studio workflows, see [Activity Coverage](https://docs.uipath.com/studio/docs/rpa-testing-activity-coverage).
   Figure 1. Enabling coverage calculation
   ![Screenshot of the Adding test set page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-adding-test-set-page-226839-d6b569fa.webp)
7. Select your Studio projects.
8. (Optional) You can edit the project version and toggle to **Include Prerelease** versions.
9. Define custom **Arguments** for your test cases to override default values at the test set level. Through the arguments, you can parameterize the test cases at runtime.
   :::note
   To define arguments, you need to have published a package with arguments.
   Figure 2. Defining arguments
   ![Screenshot of the Arguments tab](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-arguments-tab-227301-d05e1454.webp)
10. Select **Next**.
11. Use the checkboxes to select individual test cases. Alternatively, you can choose to **Select all** in the column header.
12. Select **Save**. Your test set is created and available on the **Test Sets** page.
    :::tip
    [Add test schedule](https://docs.uipath.com/orchestrator/automation-suite/2024.10/user-guide/test-schedules#test-schedules)
## Execute Test Set
You can execute individual test sets.
4. Select a test set and Select Execute.
5. Select **Ok** to confirm your action. The test set is placed in a queue. For more information, see [Test Executions](https://docs.uipath.com/orchestrator/automation-suite/2024.10/user-guide/test-executions#test-executions).
## Manage Test Sets
The following table lists the actions that you can take to manage your test sets.
 <colgroup>
  <col/>
  <col/>
  <col/>
 </colgroup>
     Action
     Procedure
    Edit
     Edit test set details, execution target, projects and test cases.
          Open your folder in Orchestrator.  2.Navigate to Testing &gt; Test Sets .
         Select a test set and go to More Actions &gt; Edit .
         Configure your test set details and then click Save .
    Clone
     Make a clone of your current test set.
         Select a test set and go to More Actions &gt; Clone .
         Configure your cloned test set details and then click Save .
    Delete
     Delete test sets.
Deleting test sets removes any associated test schedule.
         Select a test set and go to More Actions &gt; Delete .
         Click Ok to confirm.
