# Robot Settings
> Robot execution settings available in Orchestrator, managed remotely without connecting to the robot machine
Robot execution settings can be managed from Orchestrator for each robot, without having to connect to the robot machine each time.
Settings from either robot configuration or from UiPath® Assistant are overwritten with the selected setting whenever robots connect to Orchestrator or when jobs are triggered from Orchestrator.
These settings stay the same regardless of robot and folder types.
## Robot Settings
 <colgroup>
  <col/>
  <col/>
 </colgroup>
     Field
    Logging Level
     The level at which the robot should log information.  The following options are available:
         Verbose
         Trace
         Information - this is the default value.
         Warning
         Error
         Critical
         Off - use the robot settings from either robot configuration or UiPath Assistant.
    Allow Development logging
    Enables you to choose whether or not you want to receive execution or debugging logs sent from Studio during development processes.
By default, this is set to <code>Yes</code> .
    Login To Console
    Enables the Robot to connect to the console session of the machine where it is installed. Additionally, it indicates if you can connect multiple Robots to Orchestrator using multiple users (High-Density Robots) or not.
By default, this is set to <code>Yes</code> . To enable High-Density Robots, set the value to <code>No</code> . If set to <code>No</code> , the Unattended Robot creates an RDP session when executing a process.
    Resolution Width
     The machine's display resolution width.
This option is set to 0 by default, which means that it automatically retrieves and uses the detected resolution width. You can use a custom value, as long as it is supported by the workstation.
    Resolution Height
     The machine's display resolution height.
This option is set to 0 by default, which means that it automatically retrieves and uses the detected resolution height. You can use a custom value, as long as it is supported by the workstation.
    Resolution Depth
     The machine's display resolution depth.
This option is set to 0 by default, which means that it automatically retrieves and uses the detected resolution depth. You can use a custom value, as long as it is supported by the workstation. Please note that Windows 10 does not support a Resolution Depth value other than 32.
    Font Smoothing
    Enhances text recognition.
If is set to True , the Font Smoothing * option over RDP connections is turned on. This means that the target machine has ClearType turned on. By default, this is set to <code>No</code> .
    Auto Download Processes
    If enabled, available processes are automatically downloaded when the Robot agent starts.
:::note
If you want to change the Robot resolution it is recommended to use an RDP session and set the **Login To Console** option to `No`. Take into account that a new session must be created for the resolution settings to take effect, so you need to log off and then log back in again.
## Configuring Robot Settings
1. Under **Tenant** - **Manage Access** - **Access Rules**, select **Robot accounts**.
2. Then, either select **Assign robot account**, to assign a new robot and add roles, or edit an existing robot account.
3. Under **Advanced robot options**, configure execution settings for the unattended robot.
4. Select **Update**.
