industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Prerequisites
Requirements and readiness criteria for the UiPath Commercial Pricing solution, including organizational scale and data availability prerequisites.
To ensure that the UiPath solution for commercial pricing can generate accurate and actionable pricing recommendations, organizations should meet the following requirements.
Organizational requirements​
The commercial pricing solution is intended for organizations that actively review and adjust pricing decisions across products, customers, or campaigns.
To use this solution effectively:
  • Pricing ownership and decision authority should be clearly defined.
  • Teams should have established processes for reviewing and approving pricing changes.
  • Pricing decisions should be revisited regularly based on demand performance and business objectives.
Data readiness requirements​
The commercial pricing solution relies on historical pricing, demand, and cost data. The accuracy and stability of pricing recommendations depend on the volume and quality of historical data available.
Before onboarding:
  • Historical demand data should be available at the appropriate level (product, customer, or location).
  • Historical price data should reflect past pricing decisions and outcomes and should be available at the customer level.
  • Cost and margin data should be available.
  • Product and customer identifiers must be consistent across datasets.
  • Pricing guardrails and business constraints should be defined.
For detailed dataset and field-level requirements, refer to Commercial pricing data requirements.
Data requirements​
For details on the data requirements for the Commercial Pricing solution, refer to Commercial Pricing.
Limitations​
  • Supports a maximum of 100 concurrent users
  • Historical data on lost quotes are needed for certain features
Precisa de ajuda? Suporte
