industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Application connectors
Configure application connectors to pull data from external platforms and services into Peak for analysis, including connectors for major APIs and web services.
Application connectors enable you to pull data from external platforms and services into Peak for analysis and decision-making. These connectors automate data ingestion from APIs and web services, eliminating the need for manual data exports.
Available application connectors​
Peak supports the following application connectors for data ingestion:
  • Google Ads - Import advertising campaign data, performance metrics, and conversion tracking.
  • REST API - Connect to any REST-compliant API endpoint for custom data sources.
  • Webhook - Receive real-time data pushes from external systems that support webhooks.
How application connectors work​
All application connectors follow this standard configuration pattern:
  1. Authentication - Provide credentials or API keys to authorize Peak to access the external service.
  2. Configuration - Specify which data to import, including endpoints, filters, and parameters.
  3. Data mapping - Map external data fields to your Peak data schema.
  4. Scheduling - Set up automatic refresh schedules or trigger-based updates.
After configuration, Peak automatically ingests data according to your schedule, transforming it into the appropriate schema for use in your solutions.
  • Available application connectors​
  • How application connectors work​
Precisa de ajuda? Suporte
