industry-department-solutions
- Overview
- API Resources
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Suppliers
Suppliers API resource representing external vendors in the procurement process, including minimum order quantities and values for inventory planning.
The Suppliers resource represents the external vendors and supply sources used in the procurement process. Each record captures a supplier's identity and the ordering constraints they impose, such as minimum order quantities and minimum order values. Suppliers are referenced by other resources as the source_id field to establish supply relationships.
Resource Endpoint
/api/v2/ingest/object/{prefix}SUPPLIERS{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) Suppliers records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- supplier_id (string) - Unique identifier for the supplier. Used as the primary key for deduplication and UPSERT operations.
Attributes
| Attribute | Data Type | Required | Description |
supplier_id | string | Yes | Unique identifier for the supplier |
supplier_name | string | Yes | Human-readable name of the supplier |
minimum_order_quantity | integer | No | The minimum number of units that must be ordered from this supplier |
moq_unit_of_measure | string | No | The unit of measure applicable to the minimum order quantity (for example, "units", "cases") |
minimum_order_value | integer | No | The minimum monetary value that must be met per order from this supplier |
mov_unit_of_measure | string | No | The currency or unit applicable to the minimum order value (for example, "GBP", "USD") |
Relationships
Outbound References
The suppliers resource does not reference any other resource as a foreign key.
Inbound References
The following resources reference suppliers via source_id:
- order_parameters —
source_id→suppliers.supplier_id - purchase_orders —
source_id→suppliers.supplier_id - transfers —
JSON Representation
"solutionName": "INV_OOTB",
"data": [
"supplier_id": "SUP-001",
"supplier_name": "Global Parts Ltd",
"minimum_order_quantity": 100,
"moq_unit_of_measure": "units",
"minimum_order_value": 500,
"mov_unit_of_measure": "GBP"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/INV_SUPPLIERS_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
supplier_idis the primary key, used for deduplication and UPSERT operations.- The
supplier_idvalue is used as thesource_idfield in related resources such as Purchase Orders, Order Parameters, and Transfers. minimum_order_quantityandminimum_order_valueare optional. When omitted, the system assumes no minimum constraints apply.- Ensure
moq_unit_of_measureandmov_unit_of_measureare populated when their corresponding minimum values are provided.
