industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
SKU Calendar
SKU Calendar API resource defining the active date range for a product-location combination, controlling which SKUs are included in replenishment planning.
Overview​
The SKU Calendar resource defines the active date range during which a product-location combination (SKU) is considered live and eligible for replenishment planning. Each record specifies a start and end date for the SKU's activity window, enabling the system to include or exclude specific product-location pairs from planning runs based on their lifecycle status.
Resource Endpoint​
/api/v2/ingest/object/{prefix}SKU_CALENDAR{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) SKU Calendar records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product. Part of the composite primary key.
  • location_id (string) - Unique identifier for the location. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product
location_idstringYesUnique identifier for the location
start_datedateNoThe date from which the SKU is considered active at this location, in YYYY-MM-DD format
end_datedateNoThe date on which the SKU becomes inactive at this location, in YYYY-MM-DD format
Relationships​
Outbound References​
The sku_calendar resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by sku_calendar:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "start_date": "2025-01-01",
      "end_date": "2025-12-31"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_SKU_CALENDAR_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id and location_id together form the composite primary key. Both fields must be provided on every record.
  • start_date and end_date are optional. When omitted, the SKU is assumed to be permanently active or the activity window is managed externally.
  • Dates must be provided in YYYY-MM-DD format.
  • product_id must correspond to an existing record in the Products resource.
  • location_id must correspond to an existing record in the Locations resource.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
Precisa de ajuda? Suporte
