industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Products Parent Child Mapping
Products Parent Child Mapping API resource defining parent-child relationships between products for substitution and hierarchy modelling in the Rebuy & Replenishment model.
Overview​
The Products Parent Child Mapping resource defines parent-child relationships between products. Each record links a child product to its parent, along with a label and rank that describe the child's role within the hierarchy. This mapping supports substitution and product hierarchy modelling in the Rebuy & Replenishment model.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PRODUCTS_PARENT_CHILD_MAPPING{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Products Parent Child Mapping records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • child_id (string) - Unique identifier for the child product. Used as the primary key for deduplication and UPSERT operations.
Attributes​
AttributeData TypeRequiredDescription
parent_idstringYesUnique identifier of the parent product in the hierarchy
child_idstringYesUnique identifier of the child product mapped to the parent
child_labelstringYesHuman-readable label describing the child product's role or variant
child_rankintegerYesOrdering rank of the child within the parent's hierarchy
Relationships​
Outbound References​
The products_parent_child_mapping resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by products_parent_child_mapping:
  • products — parent_id → products.product_id
  • products — child_id → products.product_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "parent_id": "PROD-001",
      "child_id": "PROD-002",
      "child_label": "Small",
      "child_rank": 1
  "operationType": "UPSERT"
  "data": [
      "child_rank": 1
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_PRODUCTS_PARENT_CHILD_MAPPING_OOTB' \
  -d '{
    "data": [
        "child_rank": 1
curl -X POST \
  -d '{
    "data": [
        "child_rank": 1
Important Notes​
  • child_id is the primary key, used for deduplication and UPSERT operations. Each child product maps to exactly one parent.
  • parent_id and child_id must both correspond to existing records in the Products resource.
  • child_rank orders sibling children under the same parent; lower ranks are typically presented first.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
Precisa de ajuda? Suporte
