industry-department-solutions
- Overview
- API Resources
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Purchase Orders
Purchase Orders API resource representing outbound procurement orders placed with external suppliers, tracking order lines from placement through receipt.
The Purchase Orders resource represents outbound procurement orders placed with external suppliers. Each record tracks a single order line for a product at a location, capturing the full order lifecycle from placement through to receipt, including quantities, financial value, and current status.
Resource Endpoint
/api/v2/ingest/object/{prefix}PURCHASE_ORDERS{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) Purchase Orders records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- order_number (string) - Unique identifier for the purchase order. Used as the primary key for deduplication and UPSERT operations.
Attributes
| Attribute | Data Type | Required | Description |
order_number | string | Yes | Unique identifier for the purchase order line |
product_id | string | Yes | Unique identifier for the product being ordered |
location_id | string | Yes | Unique identifier for the destination location |
source_id | string | Yes | Identifier of the supplier fulfilling this order |
ordered_at | timestamp | Yes | Datetime when the order was placed |
order_due_date | timestamp | Yes | Expected delivery date for the order |
ordered_units | integer | Yes | Number of units ordered |
receipted_at | timestamp | No | Datetime when the order was received |
receipted_units | integer | No | Number of units actually received |
order_line_value | float | Yes | Total monetary value of the order line |
order_line_status | string | No | Current status of the order line (for example, "open", "in_transit", "received") |
Relationships
Outbound References
The purchase_orders resource does not reference any downstream resources as foreign keys.
Inbound References
The following resources are referenced by purchase_orders:
- products —
product_id→products.product_id - locations —
location_id→locations.location_id
JSON Representation
"solutionName": "INV_OOTB",
"data": [
"order_number": "PO-2025-001",
"product_id": "PROD-001",
"location_id": "LOC-001",
"source_id": "SUP-001",
"ordered_at": "2025-01-10 09:00:00",
"order_due_date": "2025-01-24 00:00:00",
"ordered_units": 200,
"receipted_at": "2025-01-23 14:30:00",
"receipted_units": 198,
"order_line_value": 2500.00,
"order_line_status": "received"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/INV_PURCHASE_ORDERS_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
order_numberis the primary key, used for deduplication and UPSERT operations.source_idshould correspond to a validsupplier_idin the Suppliers resource.receipted_atandreceipted_unitsare optional and should be populated once the goods have been physically received.order_line_valueshould reflect the total value of the order line in the relevant currency.- All timestamps must be provided in
YYYY-MM-DD HH:MM:SSformat. - Records are ingested via UPSERT: subsequent updates to the same
order_numberwill overwrite the existing record.
