industry-department-solutions
- Overview
- API Resources
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Product Cost
product_cost API resource representing the cost of products in specific regions for margin calculations and pricing decisions.
The product_cost resource represents the cost of products in specific regions. This resource stores cost information used for margin calculations and pricing decisions.
→ For business context (purpose, usage notes, how this resource is used in the solution), see Product cost dataset in the User Guide.
Resource Endpoint
/api/v2/ingest/object/{prefix}PRODUCT_COST{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) product cost records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_id (string) - Foreign key reference to products
- region_id (string) - Foreign key reference to regions
- updated_at (datetime) - Timestamp of when the record was last updated
Attributes
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
| Attribute | Data Type | Required | Nullable | Description |
product_id | string | Yes | No | Unique identifier for each product. Used to join product metadata to quotations and sales for model training and guardrails. |
region_id | string | Yes | No | Region identifier (Primary Key, Foreign Key) |
updated_at | datetime | Yes | Yes | Timestamp when the record was updated. Used to identify the most up-to-date data in the UI and when optimising prices. For model training, used to match the cost price to the date of each quote. |
product_cost | float | Yes | Yes | Cost price of the product. Used to calculate the margin/profit applied to all quotations and sales orders for model training and optimising prices. |
Relationships
Outbound References
None
Inbound References
- product - Foreign key
product_idreferences product - region - Foreign key
region_idreferences region
JSON Representation
"solutionName": "QP_OOTB",
"data": [
"product_id": "PROD-001",
"region_id": "EMEA-UK",
"updated_at": "2025-01-28T10:00:00Z",
"product_cost": 89.50
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/QP_PRODUCT_COST_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
- Foreign Key Dependencies: Requires valid
product_idandregion_idto exist in their respective tables - Margin Calculation: Used in combination with list prices to calculate profit margins
- Regional Variations: Costs may vary by region due to shipping, taxes, and local factors
- Custom Attributes: Custom attributes can be added with
POST /api/v2/schema/{objectName}/add-attribute, where{objectName}is this table's fully qualified warehouse name ({prefix}PRODUCT_COST{suffix}— for example,QP_PRODUCT_COST_OOTB), as returned by Describe a solution's schema - Data Validation: All attributes are validated according to their defined data types
Related Resources
- product - Product master data
- region - Regional definitions
- list_price - List pricing for margin calculation
