industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Stock
stock API resource for the Merchandising solution representing inventory levels per product-location combination on a daily basis.
Overview​
The stock resource represents inventory levels for products at specific locations on specific dates. This resource tracks stock quantities over time for inventory management.
Resource Endpoint​
/api/v2/ingest/object/{prefix}STOCK{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) stock records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • location_id (string) - Foreign key reference to locations
  • product_id (string) - Foreign key reference to products
  • stock_date_at (date) - Date for the stock snapshot
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
location_idstringYesNoLocation identifier (Primary Key, Foreign Key)
product_idstringYesNoProduct identifier (Primary Key, Foreign Key)
stock_date_atdateYesNoStock snapshot date (Primary Key)
stock_unitsintegerYesNoNumber of units in stock
stock_idstringYesYesAlternative stock record identifier
created_attimestampYesYesTimestamp when the record was created
updated_attimestampYesYesTimestamp when the record was last updated
Relationships​
Outbound References​
None
Inbound References​
  • location - Foreign key location_id references location
  • product - Foreign key product_id references product
JSON Representation​
  "solutionName": "MP_OOTB",
  "data": [
      "location_id": "LOC-UK-001",
      "product_id": "PROD-001",
      "stock_date_at": "2025-01-28",
      "stock_units": 450,
      "stock_id": "STK-2025-001",
      "created_at": "2025-01-28T00:00:00Z",
      "updated_at": "2025-01-28T10:00:00Z"
  "operationType": "UPSERT"
  "data": [
      "stock_units": 450,
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/MP_STOCK_OOTB' \
  -d '{
    "data": [
        "stock_units": 450,
curl -X POST \
  -d '{
    "data": [
        "stock_units": 450,
Important Notes​
  • Foreign Key Dependencies: Requires valid product_id and location_id to exist in their respective tables
  • Daily Snapshots: Captures stock levels at specific dates for historical tracking
  • Location-Specific: Stock is tracked separately for each location
  • Inventory Management: Essential for stock level monitoring and replenishment planning
  • Custom Attributes: Additional custom attributes can be added using the /STOCK/add-attribute endpoint
  • Data Validation: All attributes are validated according to their defined data types
Precisa de ajuda? Suporte
