industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Manufacturing Orders
Manufacturing Orders API resource representing production work orders governing internal manufacture of products at factory locations.
Overview​
The Manufacturing Orders resource represents production work orders that govern the internal manufacture of products at factory locations. Each record tracks a single manufacturing order through its full lifecycle, from the initial planned quantities and scheduled dates through to actual production start and end times, units produced, and current status.
Resource Endpoint​
/api/v2/ingest/object/{prefix}MANUFACTURING_ORDERS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Manufacturing Orders records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product being manufactured. Part of the composite primary key.
  • location_id (string) - Unique identifier for the factory location. Part of the composite primary key.
  • order_number (string) - Unique identifier for the manufacturing order. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product being manufactured
location_idstringYesUnique identifier for the factory or production site
order_numberstringYesUnique identifier for this manufacturing order
source_idstringYesIdentifier of the production line or internal source initiating the order
ordered_attimestampYesDatetime when the manufacturing order was created
ordered_unitsintegerYesNumber of units planned for production
expected_start_datetimestampYesPlanned datetime for production to begin
actual_start_datetimestampNoActual datetime production commenced
expected_end_datetimestampYesPlanned datetime for production to be completed
actual_end_datetimestampNoActual datetime production was completed
produced_unitsintegerNoNumber of units actually produced
statusstringNoCurrent status of the manufacturing order (for example, "scheduled", "in_progress", "completed")
Relationships​
Outbound References​
The manufacturing_orders resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by manufacturing_orders:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "order_number": "MO-2025-001",
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "source_id": "LINE-001",
      "ordered_at": "2025-01-05 08:00:00",
      "ordered_units": 500,
      "expected_start_date": "2025-01-10 06:00:00",
      "actual_start_date": "2025-01-10 06:30:00",
      "expected_end_date": "2025-01-12 18:00:00",
      "actual_end_date": "2025-01-12 17:45:00",
      "produced_units": 498,
      "status": "completed"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_MANUFACTURING_ORDERS_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id, location_id, and order_number together form the composite primary key. All three fields must be provided on every record.
  • expected_start_date and expected_end_date are required planned dates; their actual_ counterparts are optional and should be populated as production progresses.
  • produced_units and actual_start_date/actual_end_date should be updated incrementally as the order progresses.
  • The location_id for a manufacturing order should reference a location where is_factory is set to true.
  • All timestamps must be provided in YYYY-MM-DD HH:MM:SS format.
Precisa de ajuda? Suporte
