industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Products
Products API resource for the Inventory Management solution, representing the item catalogue with identity, categorization, packaging, and supplier reference.
Overview​
The Products resource represents the catalogue of items managed within the inventory system. Each product record captures the item's identity, categorisation, packaging details, and source supplier reference. Products are the central entity in the data model, referenced by nearly every other resource.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PRODUCTS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Products records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product. Used as the primary key for deduplication and UPSERT operations.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product
product_namestringNoHuman-readable name of the product
product_descriptionstringNoDetailed description of the product
product_categorystringNoCategory or classification of the product
source_idstringYesIdentifier of the primary supplier or source for this product
pack_sizeintegerYesNumber of individual units contained within a single pack
minimum_order_quantityintegerNoMinimum number of units that can be ordered at one time
product_image_urlsstringNoURL or comma-separated list of URLs pointing to product images
Relationships​
Outbound References​
The products resource does not reference any other resource as a foreign key.
Inbound References​
The following resources reference products via product_id:
  • stock_daily — product_id → products.product_id
  • pricing — product_id → products.product_id
  • order_parameters — product_id → products.product_id
  • purchase_orders — product_id → products.product_id
  • transfers — product_id → products.product_id
  • manufacturing_orders — product_id → products.product_id
  • sku_calendar — product_id → products.product_id
  • sales_daily — product_id → products.product_id
  • customer_orders — product_id → products.product_id
  • product_extra — product_id → products.product_id
  • forecast — product_id → products.product_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "product_id": "PROD-001",
      "product_name": "Blue Widget",
      "product_description": "A sturdy blue widget",
      "product_category": "Widgets",
      "source_id": "SUP-001",
      "pack_size": 12,
      "minimum_order_quantity": 24,
      "product_image_urls": "https://example.com/img/prod001.jpg"
  "operationType": "UPSERT"
  "data": [
      "pack_size": 12,
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_PRODUCTS_OOTB' \
  -d '{
    "data": [
        "pack_size": 12,
curl -X POST \
  -d '{
    "data": [
        "pack_size": 12,
Important Notes​
  • product_id is the primary key, used for deduplication and UPSERT operations.
  • source_id should match a valid supplier_id in the Suppliers resource to maintain referential integrity.
  • pack_size is required and must be a positive integer representing the number of sellable units per pack.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
Precisa de ajuda? Suporte
