industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
Data Onboarding Checklist
Checklist for tracking progress through data preparation and submission stages when onboarding to the Supply Chain & Retail Solutions Data Ingestion API.
Use this checklist to track your progress as you prepare and submit data to the Supply Chain & Retail Solutions ingestion API. Complete each item before moving on to the next stage.
Before you begin​
  • Read the Getting Started guide
  • Confirm you have access to platform.peak.ai
  • Generate a Personal Access Token (PAT) from the Access Tokens page in the platform
Gather your solution details​
Submit a support ticket if you do not have these details already.
  • Obtain your solution name (e.g., QP_OOTB)
  • Obtain your prefix (e.g., QP_)
  • Obtain your suffix (e.g., _OOTB)
  • Identify the target schema name (e.g., STAGE)
  • Identify the app name and app version of the standard schema you will roll out
  • Confirm your API base URL (if your tenant is in the Ireland region, use the default base URL https://ingestion.peak.ai; if your tenant is in any other region, use your region-specific base URL — for example, https://ingestion.peaksydney.peak.ai for Sydney — and raise a support ticket if you have not been given one. See API host and reference for details.)
Roll out the solution tables​
This step creates the warehouse tables (and matching <table_name>_failed_rows tables) you will ingest into. See Schema lifecycle for the full reference.
  • Confirm a standard schema has been saved for your appName + appVersion
  • Send a POST /api/v2/schema/rollout request for your solutionName — see the linked reference for the full payload, example request, and response
  • Verify the response lists every expected table under successfulObjects and that failedObjects is empty
  • (Optional) Use GET /api/v2/schema/solutions to confirm the rollout is registered for your tenant
Prepare your data​
Submit your data​
  • Choose your operation type: UPSERT (insert or update) or APPEND (insert only)
  • Construct your API request using the ingestion URL pattern: POST {base-URL}/api/v2/objects/{prefix}{OBJECT_NAME}{suffix} — use your tenant's base URL (see API host and reference)
  • Stay within the ingestion limits: up to 2000 rows per request and 50 requests per second per tenant
  • Send a test request with a small data sample (consider dryRun: true for a no-write smoke test) and verify a successful response
  • Review the API Guide for error codes if any validation errors are returned. A 207 Multi-Status response means part of the batch was accepted and part rejected.
  • Ingest your full dataset
A 200 response confirms your rows were accepted; they are typically queryable within seconds.
Monitor your ingestion​
  • Confirm aggregate outcomes (records ingested, pass rate, top error codes) in the Data Quality Dashboard in your Peak tenant
  • Review any failed rows in the dashboard's failed-rows detail page
  • To investigate a specific batch, note the requestId from each ingestion response and use it to filter the Data Quality Dashboard
Deploy the application​
  • Confirm the selected application and version are deployed to the Library in your Peak tenant, making it available for use
Optional​
  • Add custom attributes to extend the schema for your business needs
  • Review the default scheduled ingestion schedule (every 30 minutes) and request a custom cron for any tables that need a different one
  • When your application moves to a new version, upgrade your rolled-out schema (additive changes only — new tables and columns). See Schema lifecycle
Precisa de ajuda? Suporte
