industry-department-solutions
Este conteúdo não está disponível no idioma selecionado. Portanto, ele é exibido em inglês
API Guide
Usage notes and the base URL for all v2 Data Ingestion API endpoints in UiPath Supply Chain & Retail Solutions.
Definitions​
These descriptions are designed to support correct usage of the API. For further assistance or questions, please submit a support ticket.
NameDescriptionRequired
solutionNameA unique identifier for the rollout or solution. Example: B2C_OOTB.Yes
prefixOptional prefix applied to all generated object names. Omit to use the raw schema names.No
suffixOptional suffix appended to all generated object names. Omit to use the raw schema names.No
appNameThe application for which the objects are being deployed.Yes
appVersionThe semantic version of the application's standard schema being saved, rolled out, or upgraded.Yes
objectNameThe base object name. Exact object name matching is currently enforced during schema validation.Yes
targetSchemaNameThe schema within the data warehouse where the tables and data will be stored. Example: STAGE.Yes
operationTypeThe type of ingest operation the API should perform. Supported values: UPSERT (insert or update based on primary key) or APPEND (insert only, similar to an insert operation).Yes
dryRunWhen true, the request runs the inline validation pipeline and the response is returned without writing any rows to the warehouse. See Validation behavior for what runs in dry-run mode. Default false.No
API host and reference​
All v2 endpoints share a single host. Use this base URL for every request in this guide:
https://ingestion.peak.ai
If your tenant is deployed in a regional cluster (a spoke deployment — used when data residency requirements apply to the tenant), the API is served from a cluster-specific host instead:
https://ingestion.<cluster-identifier>.peak.ai
For example, https://ingestion.peaksydney.peak.ai. Your account manager provides the cluster identifier for your tenant. Everything else in this guide works the same way — substitute your host wherever you see ingestion.peak.ai in the examples.
Warning:
Spoke tenants must use their spoke host for every request. Calling the hub host https://ingestion.peak.ai from a spoke tenant can violate your tenant's data-residency requirements. If you don't know whether your tenant is a hub or spoke deployment, confirm with your account manager before making any calls.
An interactive OpenAPI / Swagger reference is served at the same host:
The Swagger page lists every endpoint, request schema, and response schema and lets you try requests inline. Use it as the source of truth when generating client code or validating a payload structure.
Operation types​
The API supports two operation types — UPSERT and APPEND. The right choice depends on what the downstream solution needs from the data: only the current state of each record, or the full history of how it evolved over time.
UPSERT​
  • Behavior: insert new records, or update existing records by primary key.
  • Use when: downstream only cares about the current state of each record. Re-submitting a row with the same primary key overwrites the previous version in place.
APPEND​
  • Behavior: insert only. Does not update existing records.
  • Use when: downstream needs every version of every record — for time-series analysis, audit, or model features that depend on historical state. Tables designed for APPEND typically include a temporal field (for example UPDATED_AT or SOLD_AT) in the primary key, so successive versions of the same logical entity become distinct rows.
Choosing the right operation per table​
The choice is per-table, not per-data-type. The same kind of data can need different operations in different solutions:
  • A reporting dashboard that only needs today's customer attributes → UPSERT on the customer table.
  • A pricing or recommendation model that uses how each customer's attributes evolved over time as features → APPEND on the customer table.
The solution-specific guides (such as Commercial Pricing) state the recommended operation per table where it matters. Use those as your starting point.
The operationType you submit is recorded as "upsert" or "append" on each failed row in the <table_name>_failed_rows companion table — see Audit columns added at rollout for the full list of columns the API populates automatically.
Validation behavior​
Validation runs in two stages:
  • Inline (synchronous), before the API responds — three classes of check run on every row:
    • Schema checks — column exists in the schema, types match, required fields are present.
    • Data-format and type validation — date / timestamp / numeric / boolean parse, range, length, enum membership, precision and scale.
    • Intra-payload deduplication — duplicate or null primary keys, duplicate unique keys within the same request.
    Rows that fail any of these are returned in the response's failed array and recorded to the matching <table_name>_failed_rows companion table for triage in the Data Quality Dashboard.
  • Asynchronous, after the response — cross-dataset checks that need warehouse state: primary-key / unique-key collisions against rows already persisted, and foreign-key references to rows in other tables. These do not appear in the original response; they surface in the Data Quality Dashboard.
Primary-key and unique-key collisions from the asynchronous stage are recorded to <table_name>_failed_rows. A row that violates only a foreign key is instead kept in the destination table and flagged in its PEAKAUDITERRORS column (keep-and-flag) rather than moved out — see Foreign-key checks.
A 200 OK response means every row in the request passed inline validation and was accepted for ingestion. It does not mean the rows are queryable yet, or that they have passed the asynchronous checks.
When dryRun: true, the request runs the full inline validation pipeline above but no rows are written to the warehouse — so asynchronous validation does not run either. Use it to catch schema, type, and format errors before submitting a real batch.
Object-level validations run separately. The table-level rules — freshness, missing_data_validation, and the whole-table async_foreign_key check (see Object-level validations) — are not part of the per-request pipeline above. They evaluate a whole table against the data already landed in it, and run on demand rather than in response to any single ingest request. Runs are started through Run validations on demand.
The whole-table async_foreign_key check re-evaluates every row on each run, so a foreign-key-flagged row is cleared automatically once its parent is loaded — a table no longer has to be ingested parent-before-child.
Their results surface in the Data Quality Dashboard under the OBJECT_VALIDATION error codes.
Scheduled ingestion​
Every table runs on scheduled ingestion: rows are buffered per table and flushed to the warehouse on a cron schedule (every 30 minutes by default). See Scheduled ingestion for the cron format and how to customize the schedule per table.
API limits​
The API supports ingestion of up to 2000 rows per request, with a maximum payload size of 1 MB. When ingesting larger datasets, ensure your data is split into appropriately sized batches. Rate limits are 50 requests per second per tenant.
For deletion, each request can target between 1 and 500 primary key value sets.
Response status codes​
The ingest endpoint uses three status codes to communicate the outcome of a batch:
StatusMeaning
200 OKEvery row in the request passed validation and was accepted.
207 Multi-StatusSome rows passed and some failed. Successful rows are accepted; failed rows are returned in the response's failed array with structured error details.
400 Bad RequestEvery row in the request failed validation, or the request payload itself is malformed.
Other endpoints return standard HTTP semantics: 201 Created for successful schema saves and rollouts, 404 Not Found when a referenced solution or schema does not exist, 409 Conflict when saving a duplicate appName + appVersion, and 500 Internal Server Error for unexpected failures.
Error codes​
Each validation failure returns a structured error response containing an error code, category, and message. Codes follow the pattern DI_E_XXXXX (errors) or DI_W_XXXXX (warnings, non-fatal).
Resolution guidance by category​
CategoryWhat It MeansConsumer Action
BUSINESS_VALIDATIONData value violates a schema-defined business ruleFix the data value (correct format, valid enum, within range, etc.)
SYSTEM_DATAData integrity issue (missing PK, duplicate, null PK, type mismatch)Fix the data (provide PK, remove duplicates, fill required keys, send the right JSON type)
SYSTEM_SCHEMAData structure does not match the schema definitionFix the schema/data alignment (column not in schema, PK column missing, precision/scale mismatch)
OBJECT_VALIDATIONTable-level data-quality rule breached (stale data, too few rows, unresolved foreign-key reference) — an asynchronous, table-level signal, not a per-row payload errorInvestigate the table's data freshness / volume, or load the referenced parent rows for a foreign-key flag; check the source feed and its schedule. DI_W_ codes are non-fatal warnings
Business-level validation errors — Category: BUSINESS_VALIDATION​
These come from schema-defined validation rules configured per attribute (required, range, enum, length, date/timestamp format).
#Error CodeWhen TriggeredStandard Message
1DI_E_23N01required validator: field absent from payloadRequired field is absent
2DI_E_23502nonNull validator: value is nullValue cannot be null
3DI_E_23E01nonNull validator: string is blank/emptyString value cannot be empty
4DI_E_22026minLength validator: string too shortString length is below minimum
5DI_E_22001maxLength validator: string too longString length exceeds maximum
6DI_E_22003range validator: value above max or below minNumeric value out of allowed range
7DI_E_22P02range validator: value not numericValue is not a valid number
8DI_E_22023enum validator: value not in allowed setValue is not one of the allowed enum values
9DI_E_22007dateTimeFormat validator: unparseable dateInvalid date format
10DI_E_22008timestampFormat validator: unparseable timestamp or negative epochInvalid timestamp format or epoch
System-level data validation errors — Category: SYSTEM_DATA​
These come from data integrity checks (primary key null, duplicate, type mismatch) and unique key checks.
11DI_E_23P01PK attribute value is null/empty in a rowPrimary key value cannot be null/empty
12DI_E_235052+ rows in same batch share a PK valueDuplicate primary key
13DI_E_23U012+ rows in same batch share a unique-key valueDuplicate unique key
14DI_E_22I01Value not parseable as integerValue is not a valid integer
15DI_E_22N01Value not parseable as number/floatValue is not a valid number
16DI_E_22B01Value not parseable as booleanValue is not a valid boolean
17DI_E_22S02Value not a valid stringValue is not a valid string
18DI_E_22T01Timestamp field is empty stringTimestamp value is empty
19DI_E_22P03Empty/null value during precision/scale checkPrecision/scale field is empty or null
20DI_E_22P04Precision/scale validation errorPrecision/scale validation error
System-level schema validation errors — Category: SYSTEM_SCHEMA​
These come from data type mismatches and schema structural checks.
21DI_E_42703Attribute in data row not found in schemaColumn not found in schema
22DI_E_23P02PK attribute entirely absent from a rowPrimary key column is missing
23DI_E_22T02Timestamp field is wrong JSON typeTimestamp value has wrong type
24DI_E_22P01Total digits exceed attribute precisionNumeric value exceeds allowed precision
25DI_E_22S01Decimal digits exceed attribute scaleNumeric value exceeds allowed scale
Object-level validation errors — Category: OBJECT_VALIDATION​
These come from asynchronous, table-level data-quality rules configured per table via objectValidations — freshness, missing_data_validation, and the foreign-key checks (foreign_key / async_foreign_key). The {E|W} in each code is set by the rule's severity: E for an error, W for a non-fatal warning.
26DI_{E|W}_24F01freshness rule: most-recent record is older than the configured thresholdData freshness threshold exceeded — most-recent record is older than the configured threshold
27DI_{E|W}_24M01missing_data_validation rule: fewer rows than the configured minimum landed in the time windowMissing data — fewer rows than the configured minimum landed in the time window
28DI_{E|W}_23F01foreign_key / async_foreign_key check: value has no matching row in the referenced tableForeign-key reference not found — the row is kept in the table and flagged in PEAKAUDITERRORS
Quick reference — all codes sorted​
CodeCategoryShort Description
DI_E_22001BUSINESS_VALIDATIONString too long (max length)
DI_E_22003BUSINESS_VALIDATIONNumeric out of range (min/max)
DI_E_22007BUSINESS_VALIDATIONInvalid date format
DI_E_22008BUSINESS_VALIDATIONInvalid timestamp format / invalid epoch
DI_E_22023BUSINESS_VALIDATIONInvalid enum value
DI_E_22026BUSINESS_VALIDATIONString too short (min length)
DI_E_22B01SYSTEM_DATAInvalid boolean type
DI_E_22I01SYSTEM_DATAInvalid integer type
DI_E_22N01SYSTEM_DATAInvalid number type
DI_E_22P01SYSTEM_SCHEMANumeric precision exceeded
DI_E_22P02BUSINESS_VALIDATIONValue is not a valid number
DI_E_22P03SYSTEM_DATAEmpty value for precision/scale check
DI_E_22P04SYSTEM_DATAPrecision/scale validation error
DI_E_22S01SYSTEM_SCHEMANumeric scale exceeded
DI_E_22S02SYSTEM_DATAInvalid string type
DI_E_22T01SYSTEM_DATATimestamp empty string
DI_E_22T02SYSTEM_SCHEMATimestamp wrong JSON type
DI_E_23502BUSINESS_VALIDATIONNot-null violation
DI_E_23505SYSTEM_DATADuplicate primary key in batch
DI_E_23E01BUSINESS_VALIDATIONNot-empty violation
DI_{E|W}_23F01OBJECT_VALIDATIONForeign-key reference not found (kept and flagged)
DI_E_23N01BUSINESS_VALIDATIONRequired field missing
DI_E_23P01SYSTEM_DATAPrimary key value is null/empty
DI_E_23P02SYSTEM_SCHEMAPrimary key column missing from row
DI_E_23U01SYSTEM_DATADuplicate unique key in batch
DI_{E|W}_24F01OBJECT_VALIDATIONData freshness threshold exceeded
DI_{E|W}_24M01OBJECT_VALIDATIONMissing data — fewer rows than expected in window
DI_E_42703SYSTEM_SCHEMAColumn not found in schema
Categorization logic​
Use the error code prefix to quickly identify the class of error:
DI_E_22XXX  →  Data exception       (type/format/range/precision)
DI_E_23XXX  →  Integrity constraint (null/unique/pk/required; 23F01 = foreign key, kept and flagged)
DI_E_24XXX  →  Object validation    (freshness / missing data)
DI_E_42XXX  →  Schema mismatch      (undefined columns)
DI_W_XXXXX  →  Warning              (non-fatal; e.g. DI_W_23F01 foreign-key and DI_W_24XXX object-validation warnings)
Precisa de ajuda? Suporte
