Última atualização 24 de fev de 2026
uipathctl registry seed
Registro do docker de semente.
uipathctl registry seed [flags]
Opções
      --dest-password string     Destination registry password
      --dest-registry strings    List of destination registry
                                     Note: All registry needs to have same username password
      --dest-username string     Destination registry username
  -h, --help                     help for seed
      --num-worker int           Number of workers to seed images in parallel (default 3)
      --source-password string   Source registry password
      --source-registry string   Source registry
      --source-username string   Source registry username
      --tag-file string          Path to file containing list of image/helm-chart tags
      --tar-file string          Path to the tar file containing images
Opções herdadas de comandos pai
  • Description
  • Opções
  • Opções herdadas de comandos pai
Precisa de ajuda? Suporte
