Guia de referência do uipathctl
Última atualização 11 de nov de 2024
uipathctl config add-host-admin
Adicione um administrador do host e especifique as credenciais dele.
O comando utiliza como padrão o contexto atual no arquivo kubeconfig . Se o sinalizador --kubeconfig estiver definido, ele usará o arquivo kubeconfig especificado pelo sinalizador.
uipathctl config add-host-admin [flags]uipathctl config add-host-admin [flags]
Exemplos
# Add host admin with the provided username and password in cluster
        uipathctl config add-host-admin --username newadmin --password password
        # Add host admin with the provided username, password and email in cluster
        uipathctl config add-host-admin --username newadmin --email email --password password
        # Add host admin with the provided username and password in the cluster identified by the current context in the kubeconfig file
        uipathctl config add-host-admin --username newadmin --password password --kubeconfig cluster.kubeconfig        # Add host admin with the provided username and password in cluster
Opções
-e, --email string      host admin email
  -h, --help              help for add-host-admin
  -p, --password string   host admin password
  -u, --username string   host admin username  -e, --email string      host admin email
Opções herdadas de comandos pai
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Exemplos
  • Opções
  • Opções herdadas de comandos pai
Fórum da comunidade da Uipath
Confiança e segurança
