Guia de instalação do Automation Suite no EKS/AKS
- Visão geral
- Requisitos
- Instalação
- Verificações de pré-requisito
- Exemplo de saída: verificação de pré-requisito
- Exemplo de saída: instalação do Automation Suite
- Sobre o uipathctl
- Pós-instalação
- Migração e atualização
- Atualização do Automation Suite no EKS/AKS
- Opções de migração
- Etapa 6: migração do Insights independente
- Etapa 7: exclusão do tenant padrão
- Monitoramento e alertas
- Administração de cluster
- Solução de problemas
The following example shows the output you may get after checking the infrastructure prerequisites before performing the Automation Suite installation. For details, see Checking the infrastructure prerequisites.
Checks run on nodes/aks-pool1-27380386-vmss000000
✔ [SQL(PRODUCT=TEST_MANAGER, TYPE=ADO)]
✔ [EXECUTE_NATIVE] Successfully executed command
✔ [BUILD_CLIENT] Successfully built ADO client
✔ [CONNECT] Successfully connected ADO client to DB
✔ [DB_ROLES] SQL user has the required roles to DB
✔ [DNS(FQDN=INSIGHTS.<FQDN>)]
✔ [VALIDATE_FQDN] FQDN is valid
✔ [RESOLVE_TOP_DOMAIN] Resolved http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com to [{20.9.49.161 }]
✔ [RESOLVE_SUBDOMAIN] Resolved insights.ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com to [{20.9.49.161 }]
✔ [IPS_MATCH] Subdomain resolves to top domain
✔ [SQL(PRODUCT=ASROBOTS, TYPE=ADO)]
✔ [SQL(PRODUCT=ORCHESTRATOR, TYPE=ADO)]
✔ [OBJECTSTORAGE(PRODUCT=APPS)]
✔ [CHECK_API] Object storage test passed for apps
✔ [OBJECTSTORAGE(PRODUCT=TEST_MANAGER)]
✔ [CHECK_API] Object storage test passed for test_manager
✔ [OBJECTSTORAGE(PRODUCT=PLATFORM)]
✔ [CHECK_API] Object storage test passed for platform
✔ [REDIS(PORT=6380)]
✔ [CONNECTIVITY] Successfully made Redis connection on ci-asaks3955328.redis.cache.windows.net:6380
✔ [SQL(PRODUCT=AUTOMATION_OPS, TYPE=ADO)]
✔ [SQL(PRODUCT=AUTOMATION_HUB, TYPE=ADO)]
✔ [COMPATIBILITY_LEVEL] SQL DB compatibility level meets requirement
✔ [SQL(PRODUCT=INSIGHTS, TYPE=ADO)]
✔ [COLUMNSTORE_INDEX] Columnstore index is supported for SQL DB
✔ [OPENJSON] OpenJSON is supported for SQL DB
✔ [OBJECTSTORAGE(PRODUCT=ORCHESTRATOR)]
✔ [CHECK_API] Object storage test passed for orchestrator
✔ [SQL(PRODUCT=DATASERVICE, TYPE=ADO)]
✔ [SQL(PRODUCT=APPS, TYPE=ODBC)]
✔ [BUILD_CLIENT] Successfully built ODBC client
✔ [CONNECT] Successfully connected ODBC client to DB
✔ [SQL(PRODUCT=PLATFORM, TYPE=ADO)]
✔ [OBJECTSTORAGE(PRODUCT=DATASERVICE)]
✔ [CHECK_API] Object storage test passed for dataservice
✔ [DNS(FQDN=MONITORING.<FQDN>)]
✔ [RESOLVE_SUBDOMAIN] Resolved http://monitoring.ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com to [{20.9.49.161 }]
✔ [DNS(FQDN=ALM.<FQDN>)]
✔ [RESOLVE_SUBDOMAIN] Resolved http://alm.ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com to [{20.9.49.161 }]
Checks run on nodes/aks-pool0-27380386-vmss000000
Checks run on nodes/aks-pool0-27380386-vmss000003
Checks run on nodes/aks-pool0-27380386-vmss000004
Checks run on nodes/aks-pool0-27380386-vmss000001
Checks run on nodes/aks-pool0-27380386-vmss000002
Checks run on local/
✔ [STORAGECLASS(NAME=STORAGE_CLASS)]
✔ [STORAGE_CLASS_EXISTS] Storage class managed-premium exists
✔ [LIST_NODES] Listed 6 nodes
✔ [CREATE_NAMESPACE] Created namespace prereq6g5cg
✔ [CREATE_STATEFULSET] Created statefulset storage-class-check-wthrk
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000001
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000001
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000003
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000003
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000002
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000002
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000004
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000004
✔ [LIST_PODS] Listed 1 pods on node aks-pool1-27380386-vmss000000
✔ [POD_RUNNING] Found one pod running on node aks-pool1-27380386-vmss000000
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000000
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000000
✔ [OSS(COMPONENT=MONITORING)]
✔ [OSS(component=monitoring)] Check for component monitoring passed
✔ [STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA)]
✔ [STORAGE_CLASS_EXISTS] Storage class azurefile-csi exists
✔ [CREATE_NAMESPACE] Created namespace prereqzb8mv
✔ [CREATE_STATEFULSET] Created statefulset storage-class-check-r9rzv
✔ [INGRESS]
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000000] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000000] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000001] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000001] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000002] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000002] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000003] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000003] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000004] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000004] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [CONNECTIVITY]
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [POD_TO_A] Scenario: http check between two random pods completed successfully
✔ [POD_TO_B_MULTI_NODE_CLUSTERIP] Scenario: http check between from pod to a multinode ClusterIP completed successfully
✔ [POD_TO_B_MULTI_NODE_HEADLESS] Scenario: http check between from pod to a multinode ClusterIP without a clusterIP set completed successfully
✔ [HOST_TO_B_MULTI_NODE_CLUSTERIP] Scenario: http check between from pod to a multinode ClusterIP using HostNetwork completed successfully
✔ [HOST_TO_B_MULTI_NODE_HEADLESS] Scenario: http check between from pod to a multinode ClusterIP without a clusterIP set using HostNetwork completed successfully
✔ [POD_TO_B_INTRA_NODE_CLUSTERIP] Scenario: http check between from two pods colocated on the same node via ClusterIP completed successfully
✔ [OSS(COMPONENT=CERT-MANAGER)]
✔ [OSS(component=cert-manager)] Check for component cert-manager passed
✔ [NODE(CPU >= 8, RAM >= 16GI)]
✔ [AT_LEAST_ONE_NODE] At least one node found
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000000 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000000 has 5.95% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000000 has 10.00% of pods in use. Number of pods: 10.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000000)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000000)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000001 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000001 has 6.04% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000001 has 23.00% of pods in use. Number of pods: 23.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000001)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000001)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000002 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000002 has 6.07% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000002 has 26.00% of pods in use. Number of pods: 26.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000002)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000002)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000003 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000003 has 6.41% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000003 has 23.00% of pods in use. Number of pods: 23.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000003)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000003)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000004 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000004 has 6.18% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000004 has 25.00% of pods in use. Number of pods: 25.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000004)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000004)] Node has enough RAM capacity. Has: 32882796Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool1-27380386-vmss000000 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool1-27380386-vmss000000 has 6.01% memory usage
✔ [POD_USAGE] Node aks-pool1-27380386-vmss000000 has 11.00% of pods in use. Number of pods: 11.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool1-27380386-vmss000000)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool1-27380386-vmss000000)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [REGISTRY]
✔ [CONNECTIVITY] Successfully made Registry connection on Azure Container Registry | Microsoft Azure
✔ [OSS(COMPONENT=GATEKEEPER)]
✔ [OSS(component=gatekeeper)] Check for component gatekeeper passed
✔ [OSS(COMPONENT=LOGGING)]
✔ [OSS(component=logging)] Check for component logging passed
✔ [RESOURCE]
✔ [Capacity] Cluster has enough resources to run the given requirements
✔ [NETWORK-POLICIES]
✔ [CREATE_NAMESPACE] Namespace prereqmnfk5 created
✔ [CREATE_EGRESS_NETWORK_POLICY] Created the egress network policies allow-coredns-egress and block-external-traffic
✔ [CREATE_INGRESS_NETWORK_POLICY] Created the ingress network policy: block-echo-server-ingress
✔ [CREATE_SERVICE] Service echo-server-svc created
✔ [CREATE_ECHO_SERVER_POD] Echo server pod echo-server created
✔ [ECHO_SERVER_ACCESS] Echo server is expectedly not accessible from curl pod
✔ [DELETE_CURL_POD] Curl pod curl-pod deleted
✔ [UPDATE_NETWORK_POLICY] Network policy block-echo-server-ingress updated to allow traffic
✔ [UPDATE_NETWORK_POLICY] Network policy block-external-traffic updated to allow traffic
✔ [CURL_RESULT] Traffic to pod echo-server is allowed from pod curl-pod
✔ [INGRESS]
✔ [CONNECTIVITY]
✔ [REGISTRY]
✔ [RESOURCE]
