A geração de registros no cluster falha devido a memória insuficiente
Problema conhecido e solução alternativa para falhas de geração de registro no cluster causadas por memória insuficiente no Automation Suite.
Gerar o registro no cluster requer o carregamento de arquivos de imagens grandes na memória. Em nós com RAM limitada, isso pode fazer com que o processo de geração trave ou termine inesperadamente.
Solução
Para resolver o problema, use o seguinte script para semear o registro no cluster:
#!/bin/bash
set -euo pipefail
[[ $# -lt 1 ]] && { echo "Usage: $0 <bundle>"; exit 1; }
BUNDLE=$1
OFFLINE_FOLDER="/uipath" # don't add / at the end
DOCKER_REGISTRY_NODEPORT=30071
function error() {
  echo -e "\e[0;31m[ERROR][$(date +'%Y-%m-%dT%H:%M:%S%z')]:\e[0m $*" >&2
  exit 1
function info() {
  echo "[INFO] [$(date +'%Y-%m-%dT%H:%M:%S%z')]: $*"
function warn() {
  echo -e "\e[0;33m[WARN] [$(date +'%Y-%m-%dT%H:%M:%S%z')]:\e[0m $*" >&2
function configure_podman() {
  local podman_folder="$1"
  local podman_config_path="/etc/containers/storage.conf"
  local podman_rootless_path="${podman_folder}/podman_rootless"
  local podman_rootfull_path="${podman_folder}/podman_rootfull"
  if [[ -n "${podman_folder}" ]]; then
    info "Configuring podman to use ${podman_folder}"
    mkdir -p "${podman_rootless_path}" || exit 1
    mkdir -p "${podman_rootfull_path}" || exit 1
    # update the graphroot config line
    sed -i "s|^\(graphroot[[:space:]]=\).*|\1\"${podman_rootfull_path}\"|" "${podman_config_path}"
    # uncomment and update the rootless path config line
    sed -i "s|^#[[:space:]]*\(rootless_storage_path[[:space:]]*=\).*|\1\"${podman_rootless_path}\"|" "${podman_config_path}"
  fi
  # uncomment the mount program
  sed -i "/^#mount_program[[:space:]]*=/s|^#||g" "${podman_config_path}"
function get_registry_addresses() {
  local namespace="docker-registry"
  local lh_registry=1
  local server_node_count
  lh_registry=$(kubectl get deployment -n "${namespace}" docker-registry --ignore-not-found --no-headers | wc -l)
  server_node_count=$(kubectl get nodes -l "node-role.kubernetes.io/master=true" --no-headers | wc -l)
  IFS=" " read -r -a registry_addresses <<<"$(kubectl get pods -n ${namespace} -o jsonpath="{.items[*].status.podIP}" -l app=docker-registry)"
  if [[ "${lh_registry}" -eq 1 ]]; then
    [[ "${#registry_addresses[@]}" -eq 1 ]] || error "Failed to get address of registry pod."
  else
    [[ "${#registry_addresses[@]}" -eq "${server_node_count}" ]] || error "Failed to get address of all registry pods."
  fi
  echo "${registry_addresses[@]}"
function import_sf_images() {
  local sf_folder="${1}"
  local podman_folder="${2}"
  local image_inventory="${sf_folder}/sf-images/image-tags.txt"
  local image_tar="${sf_folder}/sf-images/images.tar"
  info "Populating Docker Registry"
  if [[ -z "${podman_folder}" ]]; then
    podman_folder="${sf_folder}"
  fi
  [[ -f "${image_inventory}" ]] || error "Missing ${image_inventory}"
  local all_images_present=1
  while read -r image_name; do
    podman image exists "localhost:${DOCKER_REGISTRY_NODEPORT}/${image_name}" || all_images_present=0
  done <"${image_inventory}"
  mkdir -p "${podman_folder}/tmp"
  info "Executing podman load with podman_folder=${podman_folder}"
  # inline ENV for https://github.com/containers/podman/pull/5412 and https://github.com/containers/podman/issues/5960
  export TMPDIR="${podman_folder}/tmp"
  if ((all_images_present != 1)); then
    info "Loading image tar ${image_tar}"
    podman load -i "${image_tar}" || error "Failed to load image"
  else
    info "All images present. Skipping podman load"
  fi
  registry_addresses=($(get_registry_addresses))
    for ip in "${registry_addresses[@]}"; do
      local try=0
      local maxtry=10
      local status="notready"
      podman tag "localhost:${DOCKER_REGISTRY_NODEPORT}/${image_name}" "${ip}:5000/${image_name}"
      podman login "${ip}:5000" --tls-verify=false
      while [[ ${status} == "notready" ]] && ((try != maxtry)); do
        try=$((try + 1))
        info "Pushing image ${image_name}...try ${try}/${maxtry}" && sleep 5
        podman push "${ip}:5000/${image_name}" \
          --tls-verify=false  &&
          status="ready"
        [[ ${status} == "ready" ]] || sleep 60
      done
      [[ ${status} == "ready" ]] || error "Failed to push image $image_name"
    done
  info "Populated Docker Registry"
tmp_offline_folder="$(mktemp -d -p "${OFFLINE_FOLDER}" -t offline-bundle.XXXXXXXXXX)"
tar -xzf "${BUNDLE}" -C "${tmp_offline_folder}"
podman_folder="$OFFLINE_FOLDER/lib"
mkdir -p $podman_folder
configure_podman "$podman_folder"
import_sf_images "${tmp_offline_folder}" "$podman_folder"
#!/bin/bash
set -euo pipefail
BUNDLE=$1
function error() {
  exit 1
function info() {
function warn() {
  fi
  local lh_registry=1
  else
  fi
  fi
  else
  fi
      local try=0
      local maxtry=10
        try=$((try + 1))
          status="ready"
      done
    done
Para executar o script, use o seguinte comando:
./script.sh <path-to-bundle.tar.gz>
  • Description
  • Solução
Precisa de ajuda? Suporte
