Guia de instalação do Automation Suite no EKS/AKS
Como desinstalar o Dapr
Desinstale o Dapr do Automation Suite no EKS/AKS.
Pré-requisitos​
  • CLI do Kubectl (kubectl) instalado e configurado.
  • Permissões apropriadas para excluir recursos nos namespaces de destino.
Informação necessária​
Antes de prosseguir, você deve reunir as seguintes informações:
  • Namespace UiPath onde o Dapr é instalado.
  • Namespace ArgoCD (normalmente argocd ou openshift-gitops).
Processo de desinstalação passo a passo​
  1. Exclua o aplicativo Dapr do ArgoCD:
    # Verify the application exists first
    kubectl get application.argoproj.io dapr -n <argocd_namespace>
    # If it exists, delete it
    kubectl delete application.argoproj.io dapr -n <argocd_namespace>
    Aguarde a exclusão dos recursos.
  2. Excluir recursos personalizados Dapr:
    # Delete all Dapr components in the UiPath namespace
    kubectl delete components.dapr.io --all -n <uipath_namespace>
    # Delete all Dapr configurations in the UiPath namespace
    kubectl delete configurations.dapr.io --all -n <uipath_namespace>
    # Delete all Dapr resiliencies in the UiPath namespace
    kubectl delete resiliencies.dapr.io --all -n <uipath_namespace>
    # Delete all Dapr subscriptions in the UiPath namespace
    kubectl delete subscriptions.dapr.io --all -n <uipath_namespace>
  3. Excluir as definições de recursos personalizados (CRDs) do Dapr:
    # Delete Dapr CRDs
    kubectl delete crd components.dapr.io
    kubectl delete crd configurations.dapr.io
    kubectl delete crd resiliencies.dapr.io
    kubectl delete crd subscriptions.dapr.io
    # Delete Dapr CRDs
  4. Remova as configurações do webhook do Dapr:
    # Delete the Dapr sidecar injector webhook
    kubectl delete mutatingwebhookconfigurations dapr-sidecar-injector
  5. Remover associações de função específicas de Dapr
    # Verify if the role binding exists
    kubectl get rolebinding -n <uipath_namespace> | grep dapr
    # If it exists, delete dapr specific role binding
    kubectl delete rolebinding <dapr-role-binding> -n <uipath_namespace>
  6. Remova funções específicas de Dapr:
    # Check if the dapr-creator role exists
    kubectl get role -n <uipath_namespace> | grep dapr
    # If it exists, delete dapr specific rolekubectl delete role <dapr-role> -n <uipath_namespace>
  7. Limpar recursos restantes do Dapr
    • Pods:
      # List all Dapr-related pods
      kubectl get pods -n <uipath_namespace> | grep dapr
      # Delete each Dapr pod if any
      kubectl delete pod <pod_name> -n <uipath_namespace>
    • Serviços:
      # List all Dapr-related services
      kubectl get svc -n <uipath_namespace> | grep dapr
      # Delete each Dapr service if any
      kubectl delete svc <service_name> -n <uipath_namespace>
    • Implantações:
      # List all Dapr-related deployments
      kubectl get deployments -n <uipath_namespace> | grep dapr
      # Delete each Dapr deployment
      kubectl delete deployment <deployment_name> -n <uipath_namespace>
Verificação​
Após concluir todas as etapas de desinstalação, verifique se todos os componentes Dapr foram removidos:
# Check for any remaining Dapr resources
kubectl get crd | grep dapr
Solução de problemas​
Se alguns recursos não puderem ser excluídos:
  • Certifique-se de que você tenha as permissões necessárias.
  • Verifique se os recursos estão sendo gerenciados por outro controlador.
  • Investigue quaisquer dependências que possam estar impedindo a exclusão.
Observações​
  • Substitua <uipath_namespace> por seu namespace UiPath real.
  • Substitua <argocd_namespace> por seu namespace do ArgoCD real.
  • Tenha cuidado ao excluir recursos compartilhados que possam afetar outros aplicativos.
Precisa de ajuda? Suporte
