Guia de instalação do Automation Suite no EKS/AKS
Endpoints de integridade
Pontos de extremidade de verificação de integridade para serviços do Automation Suite no EKS/AKS.
Para monitorar com eficiência a integridade de seus serviços do Automation Suite, você pode usar os pontos de extremidade de integridade listados nesta seção. Esses pontos de extremidade permitem que você verifique rapidamente se um serviço está operando corretamente.
Plataforma​
  • https://<automation-suite-fqdn>/pap_/health
  • https://<automation-suite-fqdn>/pdp_/health
  • https://<automation-suite-fqdn>/identity_/.well-known/openid-configuration
  • https://<automation-suite-fqdn>/identity_/web/
  • https://<automation-suite-fqdn>/lease_/health/
  • https://<automation-suite-fqdn>/license_/health
  • https://<automation-suite-fqdn>/organization_/health
  • https://<automation-suite-fqdn>/portal_/portal/shallow/healthStatus
  • https://<automation-suite-fqdn>/audit_/health
  • https://<automation-suite-fqdn>/resourcecatalog_/health
Action Center​
  • https://<automation-suite-fqdn>/actions_/
  • https://<automation-suite-fqdn>/bupproxyservice_/health/ready
  • https://<automation-suite-fqdn>/processes_/
Agents​
  • https://<automation-suite-fqdn>/agents_/health
  • https://<automation-suite-fqdn>/agentsruntime_/health
AI Center​
  • https://<automation-suite-fqdn>/aifabric_/ai-app
  • https://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/ready
  • https://<automation-suite-fqdn>/aistorage_/health
  • https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Autopilot para todos​
  • https://<automation-suite-fqdn>/autopilotforeveryone_/api/health
Autopilot para desenvolvedores​
  • https://<automation-suite-fqdn>/autopilotstudio_/alive
  • https://<automation-suite-fqdn>/autopilotstudio_/health
Automation Hub​
  • https://<automation-suite-fqdn>/automationhub_/fd-api/v1/ping
  • https://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Soluções​
  • https://<automation-suite-fqdn>/automationsolutions_/health
Data Service​
  • https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/health
  • https://<automation-suite-fqdn>/dataservice_/assets
Document Understanding​
  • https://<automation-suite-fqdn>/du_/api/documentmanager/health
  • https://<automation-suite-fqdn>/du_/api/storage/health
  • https://<automation-suite-fqdn>/du_/api/eventservice/health
  • https://<automation-suite-fqdn>/du_/metering/alive
  • https://<automation-suite-fqdn>/du_/ocr/info/ready
  • https://<automation-suite-fqdn>/du_/extended-ocr/ready
  • https://<automation-suite-fqdn>/du_/classify/MLclassification/info/ready
  • https://<automation-suite-fqdn>/du_/svc/formextractor/info
  • https://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Enterprise Context Service (ECS)​
  • https://<automation-suite-fqdn>/ecs_/health
Healing Agent (Proxy Semântica)​
  • https://<automation-suite-fqdn>/semanticproxy_/health
Insights​
  • https://<automation-suite-fqdn>/insights_/health
Integration Service​
  • https://<automation-suite-fqdn>/connections_/schedulerstatus
  • https://<automation-suite-fqdn>/connections_/dispatcherstatus
  • https://<automation-suite-fqdn>/elements_/v1/elements/health
  • https://<automation-suite-fqdn>/elements_/elements/api-v2/tickle
Gateway do LLM​
  • https://<automation-suite-fqdn>/llmgateway_/health
Observabilidade de LLM​
  • https://<automation-suite-fqdn>/llmops_/health
  • https://<automation-suite-fqdn>/llmops_/tracesruntime/health
Maestro​
  • https://<automation-suite-fqdn>/pims_/api/health
Serviço de notificação​
  • https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator​
  • https://<automation-suite-fqdn>/orchestrator_/api/health
Robot UiPath​
  • https://<automation-suite-fqdn>/robotube_/healthz
Screenplay (proxy semântico)​
Governança do Studio​
  • https://<automation-suite-fqdn>/roboticsops_/api/health
Studio Web​
  • https://<automation-suite-fqdn>/studio_/backend/healthz
  • https://<automation-suite-fqdn>/studio_/typecache/healthz/readiness
Test Manager​
  • https://<automation-suite-fqdn>/testmanager_/api/health/live
Verificação da integridade do serviço​
Para verificar a integridade de um serviço específico, envie uma solicitação para seu ponto de extremidade correspondente, conforme mostrado no exemplo a seguir.
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
Uma resposta bem-sucedida com um código de status HTTP 200 indica que o serviço está íntegro.
Precisa de ajuda? Suporte
