# Automation Program
> Automation Program home page in Automation Hub, displaying all active submissions across the tenant regardless of idea source, excluding rejected, duplicate, and archived items.
This page is set up as the home page, displayed after successfully logging in, and contains **all the submissions** created within the company tenant, regardless of their idea source, except the ones in Rejected, Duplicate, Archived status or automations in Business Review - Awaiting Review. For each submission, a profile card is displayed, providing summarized information about it.
**Explore Automation Program** page displays automations collected from all submission paths ([Submit an Employee-driven idea](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/employee-driven), [Submitting a CoE-driven Idea](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/coe-driven), [Submit an Automation](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/share-an-automation), [Process Mining](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/set-up-integration-with-uipath-process-mining) or [Task Mining](https://docs.uipath.com/task-mining/docs/automation-hub-integration)).
## Searching
You can use **Search** to find specific automation ideas. Type any text or keyword to search by Automation name, Automation ID, and description.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-148053-40743181-e833025e.webp)
## Filtering
To find the list of automations you're interested in, and you can filter by the following criteria:
* Category
  + Business Area
  + Category
  + Sub-Category
Each Business Area can have from 1 to 4 levels of sub-categories, depending on how the admin has set up the structure in the [Platform Setup](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/platform-setup#platform-setup) module.
If you define common names for multiple sub-categories that belong to different business areas, you will notice multiple categories with the same name when filtering. Each of them must be selected in the filter if you want to display all ideas belonging to those categories.
Our suggestion is to avoid [naming](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/setting-up-and-managing-the-automation-categories#categories) multiple sub-categories with the same name as this could create confusion when using the filter. See below a short example of how the Categories could be structured.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-146949-613fb415-d145084c.gif)
* Application
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-147837-b29cf5c5-b0e5429f.webp)
* Submission Path
Depending on the automation ideas you want to see on the Automation Program page, you can filter by one or more submission paths.
* Submitter's Business Unit
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-149952-be5dbb79-516a3efa.webp)
* Phase
By default, all automations are displayed regardless of their current phase (except those in Rejected, Duplicate, or Archived status). The list can be filtered using the **Filter** button, and you can select the desired **Phase** and available **Status**.
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-149649-fb25a6ab-edb9ac8f.webp)
To narrow down the list even more to the automations that are **available for use**, select the **Live** phase and **In Production** status from the Phase and Status filter options.
## Requesting an Existing Automation
:::note
This feature is available only to users that have not yet migrated to Cloud.
Click on the Request button from the automation profile page to express your intention in using the automation in your day-to-day work. As soon as you click **Request**, a pop-up containing a Thank you message is displayed. Next, an email is sent, and a task is generated for the Technical Reviewers to provide the automation you requested.
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-151712-20398e0c-58be607b.webp)
To find citizen developer automations that are not yet live, filter by **Submission Path = Citizen Developer** and select all phases and statuses except **Live - In Production**.
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-147589-eb09f36d-4f8f56e8.gif)
You will get a list with all the automations that have been approved in the Business Review phase. If any of these automations present interest for you, click on the **Interested** button to express your interest in using the automation in your day-to-day work when it becomes available.
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-148073-6e1bfcb3-5973f4cb.webp)
* **Find below a graphic representation of different submissions flow**:
  + [Submit an Idea](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/submit-an-idea).
  + [CoE-driven automation idea flow](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/coe-driven).
  + [Understanding the Citizen Developer Flow](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/understanding-the-citizen-developer-framework).
