# Using Master Detail View
> You can use the **Master Detail View** to reference information from the row of a table or a custom list. By doing so, you can achieve the following:
## Overview
* Select and reference one item from a drop-down.
* Select an item from a list or table and reference columns from that record.
* Bind the selected record data within an expression. Changes to the selected item are reflected on expression-bound controls.
## Using the Master Detail View in a Table
To reference the information from a selected row in a table bound to Orchestrator output, follow the procedure below.
1. Open your already existing application or start a new one.
2. Add a button control and use it to start the process.
3. Create a table with a column called **Name**.
4. Bound the table column to an Orchestrator output by selecting it in the **Data Source** property. In this example we will pick a source called `Out.out_datatable`
![docs image](https://dev-assets.cms.uipath.com/assets/images/apps/apps-94544-f53679d8.webp)
5. Create a label and pick Name from the Table.SelectedValue category from the **Resources** in the **Text** property.
![docs image](https://dev-assets.cms.uipath.com/assets/images/apps/apps-99331-4a0df55e.webp)
6. Save the app and preview it.
7. Press the button to initiate the process.
8. Once the table is displayed, select any row from the table. The information from the **Name** column should now be displayed in the label configured at **Step 5**.
