Process Mining
Banner background image
Process Mining
Last updated Mar 11, 2024
Sending automation ideas to UiPath Automation Hub
Introduction
Different UiPath products work together to discover, investigate and build automation and communicate process improvements. UiPath Automation Hub is used to turn ideas for automation that are discovered from UiPath Process Mining into real automated implementations. You can send ideas for process improvements that are subject for automation directly from the process graph to Automation Hub.
In Automation Hub the idea will be investigated and processed. Once the automation is built, the impact should become visible in Process Mining.
Note: The Automation Hub service must be enabled on the same tenant as the Process Mining service.
Submitting automation ideas
When you identify a bottleneck in your process while monitoring, for example when a manual activity takes a long time to be executed, you might want to send a request to automate the activity to Automation Hub. You can do this directly from the process graph.
Follow these steps to submit a request for automation and send it to Automation Hub.
  1. In the process graph, click on the at the upper right corner.
    The Send to Automation Hub form is displayed at the right. See the illustration below.
  2. Select the activity that is indicated as a candidate for automation from the drop-down list.
  3. Enter a name for the automation idea in the Automation name field.
    You can, for example, use the format Activity name - Process name.
Note: the title must be a unique title within the UiPath Automation Hub instance.
  1. Enter a short description of the automation idea where you can include any pre-conditions, inputs or triggers, and outcomes in the Description field.
  2. Select the name of a category that is predefined in UiPath Automation Hub as an area for automation to which the automation idea is mapped from the Business area drop-down list.
  3. Select the applicable option from the Number of ways to complete the process drop-down list to indicate the number of ways to complete the activity that is extracted from the data.
  4. Enter a percentage value to indicate how much of the input is digital in the % of Digital Input field.
  5. Select a percentage range from the % of Structured Digital Data Input drop-down list to indicate how much of the digital input is structured.
  6. Optionally, enter the email address of a process owner who will be invited to fill in a more detailed assessment of the automation idea.
  7. Click on SUBMIT.
When you hover your mouse over an activity in the process graph, the icon is displayed in the activity. When you click on the icon, the Send to Automation Hub form is displayed at the right and the activity is selected by default.
Note: Be careful when completing the fields in the Send to Automation Hub form since the values submitted may have an impact on the automation potential or determining the ease of automation.
You can also select the Activity in the process graph and click on the icon the appears in the activity to directly select the activity that you want to indicate as a candidate for automation. See the illustration below.
The Send to Automation Hub option is also available from the context menu of an Activity. See the illustration below.
Automation submitted
When the idea for automation was successfully sent a confirmation dialog is displayed.
When you click on the hyperlink in the confirmation dialog, you are redirected to the idea in UiPath Automation Hub where you are assigned as the submitter of the idea.
  • Introduction
  • Submitting automation ideas
  • Automation submitted
