# Adding Tags, Due dates, or Automation estimates to TemplateOne
> If you want to add business data to **TemplateOne**, for example, tags, due dates, or automation estimates, you must use a connector to create a proper dataset for use with **TemplateOne**. You can add tags, due dates, or automation estimates in a similar way as for **AppOne**, for example, using the **Basic Connector**.
## Introduction
See [How to use AppOne connectors with TemplateOne](https://docs.uipath.com/process-mining/standalone/2021.10/user-guide/how-to-use-appone-connectors-with-templateone#how-to-use-appone-connectors-with-templateone).
:::note
Reference models are not supported for **TemplateOne**.
See [Adding Tags](https://docs.uipath.com/process-mining/standalone/2021.10/user-guide/adding-tags#adding-tags), [Adding Due Dates](https://docs.uipath.com/process-mining/standalone/2021.10/user-guide/adding-due-dates#adding-due-dates), [Adding Automation Estimates](https://docs.uipath.com/process-mining/standalone/2021.10/user-guide/adding-automation-estimates#adding-automation-estimates).
:::important
Always make sure that your input data is formatted according to the **TemplateOne** data model. See [Input tables of TemplateOne](https://docs.uipath.com/process-mining/standalone/2021.10/user-guide/input-tables-of-templateone#input-tables-of-templateone).
