Subscribe
UiPath Process Mining
The UiPath Process Mining Guide
Prerequisites for installation
Important
If you want to install UiPath Process Mining or any of its components, you need
access to an environment, and you need a UiPath Process Mining license. Please
consult your UiPath Process Mining contact.
Windows Server
It is recommended to use a clean installation of Windows Server.
See Hardware and Software Requirements for the supported versions.
For production environments, it is recommended to use CPUs with high single-threaded performance, an SSD for storage, and enough RAM.
Web browser
A supported web browser must be installed on the server on which you want to install UiPath Process Mining. See Hardware and Software Requirements for the supported versions.
Create the installation folder
Before you can install UiPath Process Mining you must copy the installation package to your server.
Follow these steps to create the installation folder.
Step
Action
1
Download the UiPath Process Mining installation package.
2
On the server, create a folder for UiPath Process Mining. For instance, D:\processmining.
In the rest of this guide, we will refer to this directory as <PLATFORMDIR>.
Note: For multiple installations on the same server, you must create a different folder for each installation.
3
Create the folder <PLATFORMDIR>\builds.
4
Place the installation package in the <PLATFORMDIR>\builds folder.
• Right click on the installation package.
• Select Extract All…. A sub folder is now created automatically.
In the rest of this guide, we will refer to this directory as <EXTRACTDIR>.
You have downloaded the installation package and copied it to your server. The package can now be installed.
Folder Compression
Cache files use a lot of disk space. To save disk space, it is strongly recommended to set the Compress contents to save disk space option for the UiPath Process Mining server installation folder.
Follow these steps to set the Compress contents to save disk space option.
Step
Action
1
In Windows Explorer, right click on the UiPath Process Mining installation folder <PLATFORMDIR> and select Properties....
2
On the General tab, click on Advanced....
3
Enable the Compress contents to save disk space option and click on OK (2x).
Note
If you enable the Compress contents to save disk space option, you cannot enable the Encrypt contents to secure data option.
IIS
Enable IIS on the server
You must enable IIS on the server on which you want to install UiPath Process Mining. Follow these steps to enable IIS.
Step
Action
1
Login on the server and open the Server Manager.
2
Go to the Manage menu and select Add Roles and Features.
Click on Next.
3
Click through the wizard and keep the default settings.
• In the Server Roles step, enable Web Server (IIS).
• Continue clicking through the wizard and reboot the server if necessary.
Grant permissions to IIS users
Follow these steps to grant permissions to IIS users.
Step
Action
1
In Windows Explorer, right-click on the UiPath Process Mining installation folder <PLATFORMDIR> and select Properties....
2
In the Security tab, click on Edit…, and then on Add….
3
Click on Locations…, select your local machine as the Location, and click on OK.
4
Enter IIS_IUSRS in the Enter the object names to select text box.
5
• Click on Check Names. Verify that IIS_IUSRS is prefixed with the hostname.
• Click on OK.
Note: For multiple installations with different users, use the users for that group instead of IIS_IUSRS.
6
In the Group or user names list, select IIS_IUSRS.
7
In the list below find the Full control row, check Allow.
8
Click several times on OK to apply all changes and close all windows.
Requirements for external access
By default, Process Mining is only accessible externally through HTTPS. This requires that a port must be opened for external communication to enable end-users to access the platform using a web browser. Usually, port 443 is used for external communication.
If external access is needed, then a CA Certificate is required. The IT department may already have wildcard SSL certificates for your company domain name.
Updated about a month ago
