# Data transformations
> With the introduction of unit tests in **dbt version 1.8**, the `tests:` key was renamed to `data_tests:`. For existing process apps, this results in a deprecation warning that is displayed when loading data or opening **Data transformations.**
## Message: [WARNING]: Deprecated functionality The "tests" config has been renamed to "data_tests".
### Possible cause
`` [WARNING]: Deprecated functionality The `tests` config has been renamed to `data_tests`. Please see https://docs.getdbt.com/docs/build/data-tests#new-data_tests-syntax for more information. ``
### Solution
For default process apps, you can rename the occurrences of the `tests:` config to `data_tests:` in the `dbt_project.yml` and the `sources.yml` files to fix this. For customized process apps, this can be present in other `.yml` files as well.
Check out the official dbt documentation on the [New `data_tests:` syntax](https://docs.getdbt.com/docs/build/data-tests#new-data_tests-syntax) for more information.
The following illustration shows an example `dbt_project.yml` file with `tests` renamed to `data_tests`.
![Example dbt_project.yml file with tests renamed to data_tests](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-example-dbt-project-yml-file-with-tests-renamed-to-data-tests-515328-d8423456-32e4a285.webp)
## Preview does not change after changing the query
It can occur that the Preview does not change after you changed the query and run the file.
### Possible cause
The `sql` file is identical to the one in `dbt`, as it has not been updated since the last run. If you run the file again, no changes will be detected and therefore the Preview table won't be updated. For example, if you add a `WHERE` condition and run the file, the Preview will only show the filtered records. However, if you remove this `WHERE` condition and run the file again, the Preview will still only display the previously filtered records, when it should actually show all records.
### Solution
Add, or change, a comment in the `SQL` file. This will force a `dbt` run and the Preview will be updated.
## Message: The selection criterion does not match any nodes. Nothing to do.
The following warning messages are displayed in the data run log.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-docs-image-358007-4aedff96-c21cb4a0.webp)
When you get the two warning messages `The selection criterion "+<file>.state:modified+" does not match any nodes` and `Nothing to do. Try checking your model configs and model specifications args`, it means that no changes were detected compared to the last time the queries were run. The **Preview** panels are showing the most up-to-date version of the data.
To force a complete re-run of your queries, select **Apply to dashboards**.
