# Using .mvp Connectors
> In **Process Mining** (Automation Suite), an existing **Process Mining** on-premises (standalone) connector (`.mvp` file) can be loaded using **DataBridgeAgent**. This enables you to reuse the existing Data transformations, and load the output data into a process app in **Process Mining** Automation Suite.
See [Adding a custom connector to DataBridgeAgent](https://docs.uipath.com/process-mining/automation-suite/2023.10/user-guide/adding-a-custom-connector-to-databridgeagent#adding-a-custom-connector-to-databridgeagent) for a detailed description on how to add a `.mvp` connector file created in **Process Mining** on-premises (standalone) to **DataBridgeAgent**.
