Prerequisites:
- You or an administrator previously deployed the background process you want to execute to a folder you have access to.
- An administrator allocated the unattended infrastructure for running jobs by adding a machine template object to the folder.
Start a job as yourself
- Navigate to Automations > Jobs in the folder the background process resides in.
- Click Start. The Start Job window is displayed.
- From the Process Name drop-down, select the process you want to execute.
- From the Account drop-down, select Run as Myself (Personal automation) to execute the job under your own identity. Note that this option is available only for background processes.
- Configure the other settings following the instructions provided in the Starting a job documentation.
- Click Start to start the job. The job is displayed as Pending on the Jobs page until a robot is available to pick it up.
Configure a trigger to launch jobs as yourself
- Navigate to Automations > Triggers in the folder the background process resides in.
- Click Add a new trigger. The Create trigger window is displayed.
- On the Name field, give your trigger a meaningful name.
- From the Process Name drop-down, select the process you want that trigger to launch jobs for.
- From the Account drop-down, select Run as Myself (Personal automation) to execute the jobs launched by the trigger under your own identity. Note that this option is available only for background processes.
- Configure the other settings following the instructions provided in the Managing triggers documentation.
- Click Add to add the trigger. The trigger is displayed in the Triggers page and will launch a job under your own identity according to the trigger configuration.
Updated 5 months ago
