# Using a Certificate for the HTTPS Protocol
> Configure an SSL certificate to enable HTTPS communication between Orchestrator and Robots
## Requesting an SAN SSL Certificate From the Certificate Authority
This section provides an explanation on how to enable the HTTP protocol for the communication between Orchestrator and the Robots.
It is preferable to use an SAN SSL certificate submitted to a Certificate Authority rather than a self-signed one because no certificate has to be installed on Robot computers in the former case. The SAN SLL certificate issued by the Certificate Authority is trusted by all the computers in the domain.
If the primary Orchestrator machine is registered into an Active Directory that has a local Certificate Authority and an auto-enrollment policy, the user may fill a certificate request, as described in the following procedure.
1. Select the **Windows** and **R** keys, Enter `certlm.msc` , and Select **OK** to open the **Certificates** snap-in.
2. Right-Select the **Personal** node, select **All Tasks**, then **Advanced Operations**, and **Create Custom Request**. Select **Next** in the **Before You Begin** window.
   Figure 1. Create Custom Request
   ![Screenshot of theCreate Custom Request button](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-thecreate-custom-request-button-223417-8cccac9b.webp)
3. In the **Select Certificate Enrollment Policy** window, choose **Active Directory Enrollment Policy**, and Select **Next**.
4. In the **Custom Request** window, pick a certificate template designated for web server use. It should be called **Web Server** or **Web.SAN**. If no template is defined, choose **(No template) Legacy Key**. Then, select **PKCS #10** as your request format.
   Figure 2. Custom request window
   ![Screenshot of the Custom request window](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-custom-request-window-222459-0c2aaf8e.webp)
5. In the **Certificate Information** window, Select on the **Details** button corresponding to your request, and then select **Properties** to open the **Certificate Properties** window and customize the certificate request.
   Figure 3. Certificate information
   ![Screenshot of the Certificate information page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-certificate-information-page-222575-18992cb1.webp)
6. Customize the information in the **Subject** tab as described below:
   1. In the **Subject name** section, go to **Type**, and select **Common Name** from the drop-down menu. In the **Value** field, Enter the fully qualified domain name (FQDN) of the machine, e.g. myhost.domain.local. Then Select **Add**.
   2. In the **Alternative name** section, go to **Type**, and select **DNS** from the drop-down menu. In the **Value** field, Enter the machine's FQDN (the same as in step 6.1.). Then Select **Add**.
   3. If Orchestrator is installed on multiple nodes, you need to add all these FQDNs, as described in step 6.2. Also add the FQDN of the load balancer.
      Figure 4. Subject tab
      ![Screenshot of the Subject tab](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-subject-tab-223202-e230112e.webp)
7. Customize the information in the **Private Key** tab as described below:
   1. In the **Cryptographic Service Provider** box, go to **Select cryptographic service provider (CSP)**, and check **Microsoft RSA SChannel cryptographic Provider (Encryption)**.
   Figure 5. Private Key
      ![Screenshot of the Private Key tab](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-private-key-tab-223557-89acd552.webp)
   2. In the **Key options** section, make sure **Key Size** is set to at least 2048 and **Make private key exportable** is checked.
   Figure 6. Key size
      ![Screenshot of the Key size field](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-key-size-field-222607-1402e756.webp)
   3. In the **Key type** section, make sure **Key usage** is set to **Exchange**.
   Figure 7. Key type
      ![Screenshot of the Key type field](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-key-type-field-222906-d1d1250a.webp)
8. Select **OK** in the configuration window and **Next** in the **Certificate Information** screen.
9. In the **Where do you want to save your offline request?** screen, indicate a file path and file name of your choice, e.g. `C:\Users\YourUser\Documents\sslRequest.req`, and select **Base 64** as your file format.
   Figure 8. File name and format
   ![Screenshot of the File name and File format fields](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-file-name-and-file-format-fields-222471-ec49d12b.webp)
10. After the Certificate Authority accepts the enrollment request, the certificate is visible in the Personal store.
    :::important
    If the company has a standard procedure/template for obtaining the certificate, the user should refer to that procedure.
    For other environments (e.g. without auto-enrollment policy), you may still use this document as reference for the certificate parameters.
## Creating a Self-Signed SAN SSL Certificate
If you need to quickly create an SSL certificate for testing purposes only, you may create a self-signed SAN SSL certificate.
:::important
If your Orchestrator machine is running Windows Server 2012 R2, a workaround is needed to create a self-signed SAN SSL certificate. Refer to [Creating a Self-Signed SAN SSL Certificate on a Windows Server 2012 R2 Orchestrator Machine](https://docs.uipath.com/orchestrator/standalone/2026.10/installation-guide/using-a-certificate-for-the-https-protocol#using-a-certificate-for-the-https-protocol) for more details.
### Creating a Self-Signed SSL Certificate on the Primary Orchestrator Machine
Open a PowerShell console as administrator, and issue the following commands. Don’t forget to customize values according to your environment.
$ssc = New-SelfSignedCertificate -FriendlyName "TestingCertificate" -DnsName "loadbalancer.domain.local","node1.domain.local","node2.domain.local"
$store = New-Object System.Security.Cryptography.X509Certificates.X509Store( "Root", "LocalMachine")
$store.Open("MaxAllowed")
$store.Add($ssc)
$pass = ConvertTo-SecureString -String "myPass" -Force -AsPlainText
Export-PfxCertificate -Cert $ssc -FilePath "C:\temp\testingCertificate.pfx" -Password $pass
The commands above also export the `C:\temp\testingCertificate.pfx` file for later use.
Once the certificate has been created, make sure that:
* If **ApplicationPoolIdentity** is used, in the certificate console, navigate to **Personal** &gt; **Certificates**. Then, right-click your personal Orchestrator certificate, select **All Tasks** &gt; **Manage Private Keys**, and give full permissions to both **IIS AppPool\Identity** and **IIS_IUSRS**.
* If a custom account is used, in the certificate console, navigate to **Personal** &gt; **Certificates.** Then, right-click your personal Orchestrator certificate, select **All Tasks** &gt; **Manage Private Keys**, and give full permissions to the custom user that is set on the Orchestrator Application Pool.
:::note
**IIS AppPool\Identity** and **IIS_IUSRS** are local groups and should be searched for under local machine, not under domain.
### Importing the SAN Self-Signed Certificate to Other Machines
In order to make the self-signed certificate available on others machines (secondary Orchestrator nodes / Robot machines), open a PowerShell console as administrator, and issue the following commands.
$imported = Import-PfxCertificate -FilePath "C:\temp\testingCertificate.pfx" -CertStoreLocation Cert:\LocalMachine\My\ -Exportable -Password $pass
$store.Add($imported)
### Firefox – Allowing Exceptions
Firefox handles the process a bit differently, as it does not read the certificate information in the Windows store. Rather than installing certificates, it allows you to define exceptions for SSL certificates on particular sites.
When you visit a site which has a certificate error, the warning message in the screenshot below is displayed. The URL you are trying to access is displayed in the blue area. To create an exception to bypass this warning on that specific URL:
1. Select the **Add Exception** button. The **Add Security Exception** window is displayed.
   Figure 9. Adding exceptions
   ![Screenshot of the Add Exception button](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-add-exception-button-222583-f327187b.webp)
2. In the **Add Security Exception** window, Select **Confirm Security Exception** to configure this exception locally.
   Figure 10. Adding security exceptions
   ![Screenshot of the Add Security Exception page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-screenshot-of-the-add-security-exception-page-222443-7b3fde01.webp)
   :::note
   If a particular site redirects to subdomains within itself, you may get multiple security warning prompts with slightly different URLs every time. Add exceptions for those URLs by following the steps above.
## Troubleshooting Certificates
In case you encounter problems with using a certificate with `UiPathOrchestrator.msi` (during installation or upgrade), here is where you can start your troubleshooting:
From Control Panel:
1. Open **Manage Computer Certificates** -&gt; **Personal** -&gt; **Certificates**. Identify your certificate and double-Select it. In the **General** tab there should information about its validity.
2. From a command line, run the following command to diagnose the certificate: `certutil -v -verifystore My <certificateThumbprint>` - its summary is at the end of the output.
:::note
You can find your certificate's thumbprint in the Details tab described at Step 1.
### Internal Server Error
An internal server error may occur if the certificate does not have the appropriate permissions set. Run the following as Admin to grant the necessary permissions:
import-module WebAdministration
$siteName = 'UiPath Orchestrator'
$binding = (Get-ChildItem -Path IIS:\SSLBindings | Where Sites -eq $siteName)[0]
$certLoc = "cert:\LocalMachine\MY\$($binding.Thumbprint)"
$cert = Get-Item $certLoc
$keyPath = $env:ProgramData + "\Microsoft\Crypto\RSA\MachineKeys\"
$keyName = $cert.PrivateKey.CspKeyContainerInfo.UniqueKeyContainerName
$keyFullPath = $keyPath + $keyName
$acl = (Get-Item $keyFullPath).GetAccessControl('Access')
$permission="IIS_IUSRS","Full","Allow"
$accessRule = New-Object -TypeName System.Security.AccessControl.FileSystemAccessRule -ArgumentList $permission
$acl.AddAccessRule($accessRule)
Set-Acl -Path $keyFullPath -AclObject $acl
After running the script, make sure that:
:::note
### Insights Certificate Error
If you are encountering errors when trying to change your Insights certificate, make sure to follow the instructions provided in [Updating the Insights Certificate](https://docs.uipath.com/insights/standalone/2022.4/user-guide/modifying-insights-configurations).
### Chromium-based browsers certificate error
If a certificate error occurs when using Chromium-based browsers, create a self-signed certificate with a digital signature as follows:
1. Open a PowerShell console as administrator, and issue the following commands. Don’t forget to customize values according to your environment.
   $cert = New-SelfSignedCertificate -FriendlyName "MyServerSSL" -DnsName “example01” -CertStoreLocation "cert:\LocalMachine\My" -KeyUsage DigitalSignature,KeyEncipherment,DataEncipherment -KeyAlgorithm RSA -HashAlgorithm SHA256 -KeyLength 2048 -KeyUsageProperty All -Provider "Microsoft Enhanced RSA and AES Cryptographic Provider" -NotAfter (Get-Date).AddYears(5)
   $pwd = '<your-password>'
   $SSpwd = ConvertTo-SecureString -String $pwd -Force -AsPlainText
   Export-PfxCertificate -Cert "Cert:\LocalMachine\My\$($cert.Thumbprint)" -FilePath custom_cert.pfx -Password $SSpwd
   Export-Certificate -Cert "Cert:\LocalMachine\My\$($cert.Thumbprint)" -FilePath custom_public.cer
   :::note
   The commands also export the `.pfx` file for later use.
2. Once the certificate has been created, you should also take into account the following scenarios:
   * If **ApplicationPoolIdentity** is used:
     + In the certificate console, navigate to **Personal**, then to **Certificates**.
     + Right-click your personal Orchestrator certificate, select **All Tasks**, then **Manage Private Keys**.
     + Give full permissions to both **IIS AppPool\Identity** and **IIS_IUSRS**.
   * If a custom account is used:
     + In the certificate console, navigate to **Personal**, then to**Certificates.**
     + Give full permissions to the custom user that is set on the Orchestrator Application Pool.
       :::note
