通知を受け取る
UiPath Process Mining
UiPath Process Mining ガイド
テレメトリについて
はじめに
UiPath Process Mining では、問題の診断および製品の改善を目的として、使用状況とパフォーマンスに関するデータを収集します。収集される情報には、UiPath 製品情報、オペレーティング システム、ブラウザーのバージョンに関するデータが含まれます。テレメトリ データは常に匿名で送信されます。
注:
テレメトリによって診断データが正しく送信されるようにするため、UiPath Process Mining サーバーに対して、ファイアウォールが適切に設定されているかどうかを確認することをお勧めします。
UiPath プライバシー ポリシー
The UiPath Privacy Policy contains detailed information on which personal data about you we collect, use, disclose, share or otherwise process when you are using this website, our products and our services. Please read this policy carefully to understand our views and practices on how we protect your personal data.
Examples of data that will be sent for telemetry
Generic system data
For telemetry generic system data is sent such as:
  • Computer name;
  • Server name;
  • Module code.
    This type of data is sent only once.
Performance information
Also performance data is sent for telemetry, for example the total available memory.
Information on user actions
When a user logs in, for example the current language of the app or discovery accelerator, and the default browser language are sent. When changing a dashboard for example, the name of of the dashboard the user switches to, the UID of the dashboard, the current memory usage, the time it took to switch to the dashboard are sent.
For a complete overview of all the information that is sent for telemetry, please consult your UiPath contact.
注:
Actual data or fields that relate to actual data will never be sent for telemetry.
Disabling UiPath Process Mining to send telemetry data
By default, usage data collection is enabled in UiPath Process Mining. However, you can deactivate telemetry at any time by defining the SendTelemetryData setting in the Server Settings.
Follow these steps to deactivate telemetry.
StepAction
1Go to the Settings tab of the Superadmin page of your UiPath Process Mining installation.
2Enter the following line to the Server Settings:
, "SendTelemetryData" : false
See illustration below.
3Click on SAVE.
677677
約 1 か月前に更新
テレメトリについて
改善の提案は、API リファレンスのページでは制限されています
改善を提案できるのは Markdown の本文コンテンツのみであり、API 仕様に行うことはできません。
