Abonnieren
UiPath Process Mining
The UiPath Process Mining Guide
Über Telemetrie
Einleitung
UiPath Process Mining sammelt Nutzungs- und Leistungsdaten, um Probleme zu diagnostizieren und seine Produkte zu verbessern. Die von uns erfassten Informationen können Daten zu UiPath-Produktinformationen, dem Betriebssystem und Browserversionen enthalten. Telemetriedaten werden immer anonym gesendet.
Hinweis:
Für ein korrektes Funktionieren der Telemetrie und um sicherzustellen, dass die Diagnosedaten korrekt gesendet werden, wird empfohlen, sicherzustellen, dass Ihre Firewall ordnungsgemäß für den UiPath Process Mining Server konfiguriert ist.
UiPath-Datenschutzerklärung
The UiPath Privacy Policy contains detailed information on which personal data about you we collect, use, disclose, share or otherwise process when you are using this website, our products and our services. Please read this policy carefully to understand our views and practices on how we protect your personal data.
Examples of data that will be sent for telemetry
Generic system data
For telemetry generic system data is sent such as:
  • Computer name;
  • Server name;
  • Module code.
    This type of data is sent only once.
Performance information
Also performance data is sent for telemetry, for example the total available memory.
Information on user actions
When a user logs in, for example the current language of the app or discovery accelerator, and the default browser language are sent. When changing a dashboard for example, the name of of the dashboard the user switches to, the UID of the dashboard, the current memory usage, the time it took to switch to the dashboard are sent.
For a complete overview of all the information that is sent for telemetry, please consult your UiPath contact.
Hinweis:
Actual data or fields that relate to actual data will never be sent for telemetry.
Disabling UiPath Process Mining to send telemetry data
By default, usage data collection is enabled in UiPath Process Mining. However, you can deactivate telemetry at any time by defining the SendTelemetryData setting in the Server Settings.
Follow these steps to deactivate telemetry.
StepAction
1Go to the Settings tab of the Superadmin page of your UiPath Process Mining installation.
2Enter the following line to the Server Settings:
, "SendTelemetryData" : false
See illustration below.
3Click on SAVE.
677677
Vor etwa einem Monat aktualisiert
Über Telemetrie
Auf API-Referenzseiten sind Änderungsvorschläge beschränkt
Sie können nur Änderungen an dem Textkörperinhalt von Markdown, aber nicht an der API-Spezifikation vorschlagen.
