# Structure of transformations
> Transformation structure for Process Mining app templates on Automation Suite: the models folder layout and the steps each transformation layer performs.
## Overview
The following illustration shows the transformation steps of the **Process Mining** app templates.
![Transformation steps](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-transformation-steps-522535-79973ddf-703f10d6.webp)
The `models\` folder in the **Transformations** section of **Data transformations** is organized according the structure of the transformation steps.
:::note
The **Event log** and **Custom process** app templates have a simplified data transformations structure. Process apps created with these app templates do not have this folder structure.
## 1. Input
The input step is used to load the raw data. The following operations are typically done to prepare the data for the next transformation steps:
* Select fields with the optional and mandatory macro. A field doesn't need to be present in the raw data when the optional macro is used.
* **Type** cast fields to the appropriate data types.
  :::note
  It is recommended to reduce data size already in the extraction where possible.
### Naming convention
If you expect name clashes with table names in next transformation steps, it is best practice to add the suffix `_input` to the input tables.
### Optional Fields
The input of a connector consists of mandatory and optional data. For optional fields, the `optional` macro from the `pm-utils` package should be used. This makes sure that a field gets the value `null` if it is not available in the source data. That way, all transformations will run correctly.
* Use the optional_table() macro if the whole table is optional.
## 2. Objects
In the Objects step, input tables are transformed to object tables. Each object required for the expected events should get its own table. Refer to [Designing an event log](https://docs.uipath.com/481857/2147483645/process-mining/designing-an-event-log#GUID-EDBDDBDC-9144-4CAC-B44B-0ADD682AE6E0). Additionally, supporting object can also be defined here.
In the following example 3 input tables `Invoices_input`, `Invoice_types_input`, and `Customers_input` are joined together to create the object table Invoices.
  ![Example join](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-example-join-16567-c7b5b95d-685f74b7.webp)
### Guidelines
Follow these guideline when creating an objects table.
* There is one object ID field, which is unique for each data record.
* All object fields that are needed for data analysis are present.
* All object fields have names that are easy to understand.
When applicable, the object table relates to another object via an ID field. In the following example, the invoice lines are related to the invoice object via the `Invoice_ID` field.
  ![invoice lines are related to the invoice object](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-invoice-lines-are-related-to-the-invoice-object-14967-237f826c-741499bc.webp)
### Additional transformations
Not all input tables are transformed into object tables. Also, other input tables may contain relevant information, such as the Customers table in the example. It may be convenient to define them in the Objects step as separate tables such that they can be reused in the data transformations.
If the object table names would lead to name clashes later on, add the suffix _base to the tables.
## 3. Events
:::note
The input for **Event log** and **Custom process** app templates is already a well defined event log for Process Mining. There is no need to transform the data from the source system into the events for Process Mining.
In this transformation step, event tables are created for each object. Check out [Designing an event log](https://docs.uipath.com/481857/2147483645/process-mining/designing-an-event-log#GUID-EDBDDBDC-9144-4CAC-B44B-0ADD682AE6E0). Each record in an event table represents one event that took place. There are two scenarios on how the data is structured:
* **Timestamp fields**: Fields on an object table with a timestamp for an event. For example, the `Invoice_created` field in an `Invoices` table.
* **Transaction log**: A list of events.
Based on how the data is structured, the transformations to create the event tables are different.
### Timestamp fields
In this scenario, the values of a timestamp field must be transformed into separate records in an event table. The following example is an invoices table that contains three timestamp fields.
  ![invoices table with three timestamp fields](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-invoices-table-with-three-timestamp-fields-16066-595bbcfd-f2252841.webp)
Each timestamp field is used to create a separate event table. For every record that the timestamp field contains a value, create a table with the Invoice ID, the name of the event (Activity), and the timestamp the event took place (Event end).
  ![Invoices table split into separate events tabeles](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-invoices-table-split-into-separate-events-tabeles-14529-13cd952c-e2b64fb7.webp)
The `Invoices_input table` is split into `Invoice_events_Create_invoice`, `Invoice_events_Delete_invoice`, and `Invoices_events_Change_invoice_price`.
The separate event tables can then be merged into a single event table per object, for example `Invoices_events`.
### Transaction log
If events are stored in a transaction log, the relevant events per object should be identified. Create a table per object and store corresponding object ID, the name of the event (Activity), and the timestamp the event took place (Event end).
In the following example, the transaction log contains events for the **Purchase Order** and **Invoice** objects.
  ![Transaction log and event tables](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-transaction-log-and-event-tables-522726-c570d274-f1481d58.webp)
The following fields are mandatory in an event table. All records in the event tables should contain a value for these fields.
| Field | Description |
| Object ID | ID of the object for which the event happens. For example, the **Invoice ID**. |
| Activity | The activity describes which action took place on the object. |
| Event end | The event end field indicates when the specific event was finished. Ideally, this should be a datetime field, rather than a date. |
Name the tables according to the `[Activity] + _events` to create one event file per activity, or `[Object] + _events` to create one event file per object. For example `Purchase_order_created_events`, `Purchase_order_approved_events`, or one file with all purchase order activities combined `Purchase_order_events`.
## 4. Event logs
### Single object process
When the process contains one object, no additional transformations are needed in this step. The single object table and events tables are already in the correct format.
### Multiple objects process
When multiple object are involved in a process, the events of all objects need to be linked to the main object that is considered the “Case” in the process. Refer to [Define the event log](https://docs.uipath.com/481857/2147483645/process-mining/designing-an-event-log#GUID-74C9085B-DC9F-432A-A524-CD820AE31041) for details. The following steps describe how to relate all events to the main object, and how to combine them a single event log.
### Object relations
Create an “object-relations” table to centralize the relationships between all object. This object-relations table will contain the ID fields of the related objects.
To create the objects-relations table, join all object tables based on their ID fields:
* Start with the main object
* Join related objects to the main object with a left join.
* If objects do not relate directly to the main object, left join them to the related objectsthat are already joined to the main object.
In the following example, there are three objects: **Purchase order**,**Invoice line**, and **Invoice**. The **Purchase order** is considered the main object in the process. The **Invoice line** is directly linked to the **Purchase order** and the **Invoice** is linked indirectly via the **Invoice line**.
  ![Example objects](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-example-objects-15517-ac773ca1-f2d99327.webp)
  ![Example object tables](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-example-object-tables-15245-8d5728d7-6ffa2851.webp)
Object_relations as (
    select
        Purchase_orders."Purchase_order_ID"
        Invoice_lines.Invoice_line_ID
        "Invoices.Invoice_ID"
    from Purchase_orders
    left join Invoice_lines
        on Purchase_orders."Purchase_order_ID" = "Invoice_lines."Purchase_order_ID"
    left join Invoices
        on Invoice_lines."Invoice_ID" = Invoices."Invoice_ID
The following illsutration shows the resulting object-relations table.
![object-relations table](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-object-relations-table-14853-289e7e13-82dc4e9f.webp)
### Relation tables
The individual relations between the main object and each other objectsobject are stored in separate tables, using the combined information from the object relations table.
Relation_invoice_lines as (
    select
        Object_relations."Purchase_order_ID"
        Object_relations."Invoice_line_ID"
    from Object_relations
    group by "Purchase_order_ID", "Invoice_line_ID"
![Example relations table](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-example-relations-table-16250-ffa927ea-76c3112c.webp)
Relation_invoices as (
    select
        Object_relations."Invoice_ID"
    group by "Purchase_order_ID", "Invoice_ID"
![Example relations table](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-example-relations-table-15081-f3c88a2c-613434d9.webp)
### Event log
The next step is to use these relations to add corresponding “Case ID” to each event table. The "Case ID" is obtained via the relation table, where the event information is obtained from the event table. To create the full event log, the event tables for each object are unioned.
Purchase_order_event_log as (
    select
        Purchase_order_events."Purchase_order_ID"
        Purchase_order_events."Activity"
        Purchase_order_events."Event_end"
    from Purchase_order_events
    union all
    select
        Relation_invoice_lines."Purchase_order_ID"
        Invoice_line_events."Activity"
        Invoice_line_events."Event_end"
    from Invoice_line_events
    inner join Relation_invoice_lines
        on Invoice_line_events."Invoice_line_ID" = "Relation_invoice_lines."Invoice_line_ID"
    union all
    select
        Relation_invoices."Purchase_order_ID"
        Invoice_events. "Activity"
        Invoice_events. "Event_end"
    from Invoice_events
    inner join Relation_invoices
        on Invoice_events."Invoice_line_ID" = Relation_invoices."Invoice_line_ID"
If the event log table name can lead to name clashes at a later stage, add the suffix `_base` to the name of the event log tables.
## 5. Business logic
In the last transformation step, business logic is added as needed for data analysis. Additional derived fields can be added to existing tables here. For example, specific throughput times or Boolean fields that are used in KPIs in dashboards.
In **Process Mining**, there are two additional standard tables defined in this transformation step: `Tags` and `Due dates`.
### Tags
Tags are properties of objects, which signify certain business rules. Tags are typically added to make it easy to analyze these business rules. For example:
* Invoice paid and approved by the same person.
* Invoice approval took more than 10 days.
* Check invoice activity skipped.
Each record in the tags table represents one tag that occurred in the data for a specific case. The mandatory fields for this table are the `Object ID` and the `Tag`. Not all objects will have a tag and some objects may have multiple tags. The following illustration shows an example Tags table.
  ![Example Tags table](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-example-tags-table-522664-b0581bc2-b8e402d2.webp)
:::note
Only one Tags table is allowed in the data model.
### Due dates
Due dates represent deadlines in the process. These are added to the data to analyze whether activities are performed on time for these due dates or not.
Each record in the due dates table represents one due date for a certain object. Example due dates are:
* a payment deadline for a payment.
* an approval deadline for an purchase order.
The mandatory fields for this table are the `Object ID`, `Due date`, `Actual date`, and `Expected date`.
  ![Example Due dates table](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-example-due-dates-table-522673-119ede90-92fc00c3.webp)
:::note
Only one Due dates table is allowed in the data model.
