# Vertical Bar Charts
> Vertical bar charts, or distribution charts, can be used to show the distribution of values of a numerical field. The bars are displayed vertically. See the illustration below for an example.
## Introduction
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-16553-c97c9b52.webp)
In a vertical bar chart, you select the field for which you want to display values on the X-axis. The Y-axis is used to display the variable values defined by a metric. By default, the metric displayed on the Y-axis is the record count. If you want to display a different value, you can choose a different metric.
## Properties
You can edit the properties of a vertical bar chart in the **Edit vertical bar chart** panel. See the illustration below.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-253561-ecd05388.webp)
Below is a description of the elements of the **Edit vertical bar chart** panel.
| Property | Description |
| Title | Text box that enables you to edit the title of the vertical bar chart. |
| Field | Combo box that enables you to select the field that defines the values displayed on X-axis. |
| Metric | Combo box that enables you to select the metric that defines the values displayed on Y-axis. |
| Remove chart | Button that enables you to remove the chart. See [Dashboards](dashboards.md). |
