# Downloading DataBridgeAgent
> DataBridgeAgent download location and version compatibility requirements for use with Process Mining on Automation Suite.
Use the following link to download DataBridgeAgent: https://download.uipath.com/ProcessMining/versions/21.10.4/DataBridgeAgent/DataBridgeAgent-21.10.4.zip
:::note
You can only use `.mvp` connectors of a **Process Mining** on-premises standalone version that is the same version as the DataBridgeAgent. (v2021.10.4).
**DataBridgeAgent** is a standalone tool. It is recommended to create a separate folder on the server to use **DataBridgeAgent**.
:::note
Make sure to install **DataBridgeAgent** in a folder on the `C:\` drive. Since **DataBridgeAgent** contains connectors that have rather long names, file paths can become very large, which may cause issues when running the `datarun.bat` file to create the dataset. Do **not** install **DataBridgeAgent** in the in the Process Mining installation folder (`PLATFORMDIR`). Also, do **not** install **DataBridgeAgent** in the **Downloads** folder.
