# Process Mining
> Process Mining on Automation Suite enables on-premises deployment of the full UiPath suite on customer infrastructure, including Azure, AWS, and Google Cloud Platform environments.
## Introduction
Process Mining is available in Automation Suite, to be installed on premises in the customer local environment or Virtual Machines on Azure, Amazon Web Services or Google Cloud Platform​.
Process Mining on Automation Suite, enables our customers to install the full UiPath® Suite of products on premises.
The main benefits of the Automation Suite are:
* All UiPath® products in a centralized on-premises location​
* Same interface and features as in the Software as a Service version​
* Back up and Restore
* Monitoring and Alerting​
* High Availability
## Installation and configuration
For information on installing and configuring **Process Mining** on Automation Suite, refer to the [Automation Suite Guide](https://docs.uipath.com/automation-suite).
[Configuring Microsoft SQL Server](https://docs.uipath.com/automation-suite/v2023.4/docs/multi-node-configuring-ms-sql-server) contains detailed information on configuring Microsoft SQL Server for Process Mining. To calculate the hardware requirements for the Process Mining SQL Server database for data storage for Process Mining process apps, check out [Hardware requirements](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/system-requirements#system-requirements). If you want to manually add Process Mining in the "cluster.json" configuration file, instead of using the interactive installer, check out [Manual: Advanced installation experience](https://docs.uipath.com/automation-suite/v2023.4/docs/advanced-installation-experience#process-mining-specific-configuration).
## From data to dashboard
This page describes the steps to roll out a customized version of a process app to business users. It starts with the creating a new app and covers all the steps needed to provide the data in a meaningful way to end-users.
:::important
Make sure you have the required permissions. Check out [Setting up the users](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/setting-up-the-users#setting-up-the-users) and [Managing access for process apps](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/managing-access-for-process-apps#managing-access-for-process-apps).
### Development lifecycle
The following image provides a schematic overview of the development lifecycle of a process app.
  ![A schematic overview of the development lifecycle](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-a-schematic-overview-of-the-development-lifecycle-466672-cace5101-0b54c203.webp)
### Step 1. Create a new app
In the **Process Mining** portal, go to the **Development** tab and create a new process app.
:::note
For performance and security reasons, it is strongly recommended to use a small dataset for development. Refer to [Development tab](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/process-mining-portal#development-tab) for more information on using a development dataset.
Refer to [Create new app wizard](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/create-new-app-wizard#create-new-app-wizard) for a detailed description of the steps to create a process app, and the different process mining types.
### Step 2. Edit the dashboards
After creating a process app, you can edit the dashboards to customize the process app to your business needs. The **dashboard editor** provides various options to create different views, and to organize, group, and filter data. Refer to [Working with the dashboard editor](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/working-with-the-dashboard-editor#working-with-the-dashboard-editor) for more information on editing dashboards and charts.
Optionally, with **Process manager** you can update the process model type or import a BPMN model. Refer to [Process models](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/process-manager#process-models "Select the menu in the header bar of the dashboard editor and select Process models from the drop-down menu. The Process models page is displayed, showing the preview of the Discover process model or Import BPMN model.") for details.
Furthermore, with **Automation manager,** you can manage and configure automations connected to Process Mining. Refer to [Automation manager](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/automation-manager#automation-manager "Automation manager enables you to manage automations connected to Process Mining. With Automation manager you can select Orchestrator queues to be used for automations triggered by business users from the process app.Select the menu in the header bar of the dashboard editor and select Automations from the drop-down menu. The Automation manager page is displayed, showing the automations defined for your process app.") for details.
### Step 3. Edit the data transformations
Edit and test the data transformations to make sure the data used in the process app reflects your business process correctly. With **Data transformations,** you can view and edit the data model and customize the data used for Process Mining. The data preview panel helps you check if the data looks as expected. Refer to [Data transformations editor](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/data-transformations#data-transformations-editor) for details.
With **Data manager**, you have the ability to edit data fields, add or modify metrics, change the display names used within your app, and manage their visibility. Refer to [Data manager](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/data-manager#data-manager) for details.
### Step 4. Publish the process app
You can use the **Preview** option to find out how your changes to the process app will look in end-user mode before publishing any alterations.
When you have finished the customization of the process app, you can publish the process app to make the changes available to end users. Refer to [Publishing Dashboards](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/publishing-dashboards) for details.
### Step 5. Upload data
Upload production data for the published process app. Refer to [Loading data](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/loading-data) for a detailed description of the different options for uploading data.
Your process app is now available for business users to use and analyze the data incorporated within the process app. Refer to [Working with process apps](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/working-with-process-apps) for more information on the actions users can perform with process apps.
## App templates
With **Process Mining**, you can create new process apps based on process-specific app templates. An app template contains a predefined set of dashboards and KPIs for process analysis and can be used as the starting point for creating your process apps. If available, an app template can include a built-in connector for a specific combination of a process and source system.
**Process Mining** offers out-of-the box app templates for several processes and source systems that you can use as the starting point for creating your process apps. You can customize these app templates to your business needs and publish them with a set of dashboards and KPIs to enable business users to monitor and analyze the processes in detail.
## Extracting and loading data
When you create a new process app, you must upload data before you can publish the process app. You can also upload data for a published process app. You can use a sample dataset, upload a dataset with **.csv** files, or load data using an extractor.
### Data volume
The performance end-users will experience is directly related to the data volume. The number of rows inside the biggest tables determines the data volume. In general, only the number of rows determines the performance that end users experience. The number of columns is only a factor when the data is loaded from the database.
Processes with about 600.000 (600K) objects and up to about 100.000.000 (100M) events per process are ideal. With more objects and events, parsing the data and showing the visualization will take longer. Process Mining will continue to work. However, when large amounts of data are inserted, the reaction speed may drop.
It is recommended to check the data amount beforehand. If it exceeds the above numbers, it is advised to consider optimizing or limiting the dataset.
## Editing data transformations
Transformations are applied to the data stored in the database to make sure the data adheres to a data schema which can be loaded in the **Process Mining** process app. In **Process Mining**, you can customize the transformations to adapt them to your data schema.
## Customizing process apps
### Dashboard editor
After creating a process app from an app template, you can edit the dashboards to customize the process app to your business needs. The Dashboard editor provides various options to create different views, and to organize, group, and filter data.
### Data manager
The **Data manager** enables you to customize the data used in your process app. With Data manager, you can edit data fields and metrics to change the display names used in your app. Besides, you can toggle fields to be visible or not.
### Data transformations
With the inline editor, you can edit the **Data transformations** of your app directly in the browser. This means you do no longer have to export and import your transformations. Once you are done editing, you can run your customized transformations from the inline transformations editor.
## Root cause analysis
With **Root cause analysis**, you can compare the influence of object properties on a certain behavior to find significant data influencers for specific process situations. A set of objects is defined based on the period filter. This selection is called Reference objects. Within this set of objects, you can select the behavior that you want to analyze. Check out [Root cause analysis](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/root-cause-analysis#root-cause-analysis).
## Comparing process paths
When in **Compare** mode, you can compare two sets of paths from your process. This enables you to visualize, compare, and analyze the performance of a process and its variations. Check out [Compare](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/compare#compare).
## Simulating automations
The **Automation potential** dashboard enables you to detect potential savings for activities in your process. For example, if you determine an activity as a bottleneck in the process graph, you can calculate the impact of automating the activity. Check out [Simulating automation potential](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/simulating-automation-potential#simulating-automation-potential).
## Send automation ideas to Automation Hub
The integration with **Automation Hub** enables you to send automation ideas from **Process Mining** directly to **Automation Hub**. Check out [Sending automation ideas to UiPath Automation Hub](https://docs.uipath.com/process-mining/automation-suite/2.2510/user-guide/sending-automation-ideas-to-uipath-automation-hub#sending-automation-ideas-to-uipath%C2%AE-automation-hub).
## Managing access control for process apps
The **Admin console** module enables you to manage access by assigning roles to users or groups. The permissions model allows you to integrate all your employees using Process Mining based on your business requirements.
