industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Roles and permissions
Roles and permissions in Peak, including default roles, how to create custom roles, and the permissions available for controlling access to features and data.
Roles group permissions so access can be assigned to multiple users at once. Users must belong to at least one role to access Peak.
To manage roles, open Settings and select Roles. You must have Admin privileges to access this area.
Default roles​
Default roles are fixed and cannot be edited. You can view role details or add users to them, but you cannot change their permissions.
Peak includes these default roles:
RoleDescription
AdminFull access to the platform for resource and access control. Assign this role only to Peak Admin users in your organization — never to customers.
Power UserUses multiple areas of Peak to solve business use cases.
Commercial UserUses Work areas for decision intelligence.
Custom roles​
If no default role fits a user's needs, you can create a custom role with a specific combination of permissions. For example, a "Reporting User" role might have read access to multiple Work areas, and can then be assigned to all members of a reporting team.
Creating a custom role​
Follow these steps to create a custom role:
  1. In Peak, open Settings and select Roles.
  2. Select Create role.
  3. Enter a role name using alphanumeric characters and @, -, or &.
  4. Select Next.
  5. For each platform area, select Read, Write, or Deny.
  6. Select Create role.
The new role appears in the Custom roles list.
Updating or deleting a custom role​
Follow these steps to update or delete a custom role:
  2. In Custom roles, open the action menu for the role.
  3. Select View role details to edit permissions.
  4. Select Edit permission, then update permissions and select Save.
  5. To rename a role, open the action menu and select Rename.
  6. To delete a role, open the action menu and select Delete.
  7. Confirm the update or deletion.
The role is updated or removed. Deleted roles no longer grant access to users.
Adding users to a role​
Assign users to roles to grant them the appropriate Peak access. Users can be added to one or more roles, and their permissions are the union of all assigned roles.
Follow these steps to add users to a role:
  2. Open the action menu for the target role.
  3. Select Add users.
  4. Select one or more users.
  5. Select Save.
The selected users inherit the permissions of the role.
Permission levels​
Each platform area can be assigned one of the following permission levels:
PermissionMeaning
ReadView content without making changes.
WriteView and change content.
DenyNo visibility or access to the section.
Permission examples​
ScenarioRequired permissions
Allow a user to upload a fileManage > Write: Data Sources, Files
Allow a user to download a fileWork > Write: Downloads
Allow a user to interact with a dashboardWork > Read or Write: Apps
API keys​
API keys authenticate access to Peak APIs and data ingestion endpoints. An API key identifies and authenticates an application or user when calling an API. API keys help control and monitor API usage.
Peak uses API keys to authenticate API connections to external systems and to run processes such as data ingestion and data export. API keys are generated and managed in Settings.
Create a new API key in these scenarios:
  • Your Peak organization is new.
  • An existing API key has expired.
Key limits and expiration​
  • Keys are valid for three months.
  • Up to two API keys can be active at a time.
Create an API key​
Follow these steps to create a new API key:
  1. In Peak, open Settings and select Access tokens.
  2. In API keys, select Add.
  3. Copy the generated key for use in your applications.
Delete an API key​
Follow these steps to delete an API key:
  1. In API keys, open the action menu for the key.
  2. Select Delete.
If a key is near expiration, create a new key or contact Peak Support to request an extension. If you create a new API key, update it everywhere the previous key is used.
External credentials​
External credentials store repository access tokens securely for use in Workspaces, Workflows, and Web Apps.
Do not store credentials as plain text in repositories or input parameters, because other users can discover and copy them. External credentials provide a single managed location for these secrets, so you only need to refresh keys in one place.
Supported repositories​
You can add external credentials for these repository systems:
  • Custom
  • Bitbucket
  • GitHub
  • GitLab
Add an external credential​
Follow these steps to add a new external credential:
  2. In External credentials, select Add.
  3. Enter a name and select the credential type.
  4. Enter the required repository credentials.
  5. Select Submit.
Update or delete a credential​
  • To edit a credential, select the pencil icon and update the values.
  • To delete a credential, select the trash icon.
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
