industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Order parameters dataset
Order parameters dataset containing planning configuration per product, location, and supplier combination, used by Rebuy & Replenishment for replenishment recommendations.
The order parameters dataset contains planning configuration data for each product, location, and supplier combination. It defines the timing and service assumptions used by the Rebuy & Replenishment capability when calculating inventory parameters and replenishment recommendations.
This dataset plays a critical role in determining how inventory decisions are evaluated over time.
Purpose​
The Rebuy & Replenishment capability uses the order parameters dataset to:
  • Understand how frequently inventory is reviewed and replenished
  • Calculate the ordering cycle (also known as the risk period)
  • Evaluate demand volatility over lead times and review periods
  • Support accurate safety stock and replenishment calculations
During presales, this dataset is also used to validate planning assumptions and assess potential inventory improvements.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product SKU.stringPrimary key
location_idIdentifier for the store or distribution centre where the product is delivered.stringPrimary key
source_idIdentifier for the supplier or internal distribution centre. Can represent an external supplier or an internal source.stringNon-null
review_period_daysNumber of days between reviewing purchase orders. May be determined during scoping.intNon-null
service_levelTarget service level for the product, expressed as a value between 0 and 1. May be determined during scoping.floatNon-null
lead_time_daysNumber of days between placing an order and receiving the product.intNon-null
minimum_guardrailMinimum inventory guardrail quantity applied when generating replenishment recommendations.intNullable
Usage notes​
  • The ordering cycle for a product is calculated as the sum of the lead_time_days and review_period_days.
  • If review_period_days or service_level values are not provided, they may be defined during onboarding or scoping.
  • Identifiers (product_id, location_id, source_id) must align with the corresponding Products, Locations, and Suppliers datasets.
  • This dataset typically changes less frequently than demand or stock data but is critical to planning accuracy.
  • Purpose​
  • Required fields​
  • Usage notes​
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
