industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Products dataset
Products dataset for the Inventory Management solution, containing product metadata used across inventory analysis and reporting as a reference dataset.
The Products dataset contains metadata for the products managed by the UiPath solution for inventory management. It defines the items that are planned and provides descriptive and categorical information used across inventory analysis and reporting.
This dataset acts as a reference dataset and is joined to other datasets, such as Customer orders, Stock, Pricing, and Order parameters, using the product_id.
Purpose​
The solution uses the Products dataset to:
  • Identify the products included in inventory planning
  • Enable analysis at both individual product and aggregated levels
  • Support reporting and categorization across product hierarchies
  • Ensure consistent product identifiers across all datasets
During presales, this dataset is also used to validate product coverage and support category-level analysis.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product SKU. Must match across all related datasets.stringPrimary key
Unique
product_nameName of the product. Improves readability and reporting.stringNullable
product_descriptionDescription of the product. Provides additional context.stringNullable
product_categoryCategory or type of the product. Enables aggregated analysis at a category level.stringNullable
source_idIdentifier for the supplier or internal distribution centre associated with the product.stringNon-null
pack_sizeNumber of units contained in a single pack of the product.integerNon-null
minimum_order_quantitySmallest quantity of the product that can be ordered at one time.integerNullable
product_image_urlsURL(s) referencing images of the product.stringNullable
Usage notes​
  • Every product referenced in other datasets (for example, Customer orders, Stock, Pricing, Purchase orders, or Transfers) must exist in the Products dataset.
  • The product_id must be consistent across all datasets.
  • Product category information is optional but strongly recommended to support higher-level analysis and reporting.
  • Units of measure associated with products must be consistent with related datasets (for example, Stock and Customer orders).
  • If supplier relationships vary by location, this relationship should be reflected in the relevant datasets (for example, Order parameters), not encoded solely in the Products dataset.
Why this dataset matters​
The Products dataset defines the scope of inventory planning. Without a consistent product reference dataset, the solution cannot reliably join demand, stock, pricing, and replenishment data or generate meaningful inventory insights.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
