industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Product cost dataset
Product cost dataset containing unit cost information per product over time, providing the financial context for margin and profitability analysis in Commercial Pricing.
The Product Cost dataset contains cost information for products used in commercial pricing scenarios. It defines the unit cost of products over time and provides the financial context necessary to evaluate margin and profitability.
This dataset is required for application deployment and pricing insights analysis.
→ For the canonical technical schema (data types, validation rules, request/response examples), see Product Cost in the API Guide.
Purpose​
The commercial pricing solution uses the Product Cost dataset to:
  • Calculate product-level margins
  • Evaluate profitability of quoted or recommended prices
  • Support trade-off analysis between revenue and margin objectives
  • Ensure pricing guardrails reflect cost constraints
Cost data is essential for generating pricing recommendations that balance competitiveness and profitability.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for each product.stringPrimary key
region_idRegion identifier.stringPrimary key
updated_atTimestamp when the record was updated.timestamp_tzPrimary key
product_costCost price of the product.floatNon-null
Custom fields​
The fields listed previously are the standard schema for this dataset. A field that your business requires but the standard schema does not include can be added as a custom attribute after the schema is rolled out. Custom attributes are additive, so they extend the dataset without affecting existing fields, and they are validated in the same way as standard fields.
The following request adds a COST_SOURCE column to this dataset:
curl -X POST \
  'https://ingestion.peak.ai/api/v2/schema/QP_PRODUCT_COST_OOTB/add-attribute' \
  -d '{
    "solutionName": "QP_OOTB",
    "columnName": "COST_SOURCE",
    "dataType": "string",
    "validations": [
      { "type": "optional" }
curl -X POST \
  -d '{
    "validations": [
The table name in the request URL is this dataset's fully qualified warehouse name, which includes the prefix and suffix configured when your solution was rolled out — QP_PRODUCT_COST_OOTB in this example. Retrieve the name for your own solution with Describe a solution's schema.
On standard tables the API prefixes the new column name in the warehouse with C_ (Snowflake) or c_ (Redshift), so COST_SOURCE becomes C_COST_SOURCE and warehouse queries must use the prefixed name.
→ For the full parameter reference, supported data types, and validation rules, see Customizations in the API Guide.
Usage notes​
  • Cost data should reflect the actual cost basis used for margin calculations.
  • All referenced identifiers (product_id, region_id) must exist in their corresponding datasets.
  • Successive versions of a product cost are appended with new updated_at values, preserving the cost history needed for accurate profitability analysis over time.
  • Historical cost changes improve the accuracy of profitability analysis and recommendation stability.
  • Units of measure must be consistent with related datasets (for example, Quote Line and Sales).
Why this dataset matters​
The Product Cost dataset enables the solution to evaluate pricing decisions against profitability objectives. Without cost data, pricing recommendations cannot reliably assess margin impact or enforce pricing guardrails.
  • Purpose​
  • Required fields​
  • Custom fields​
  • Usage notes​
  • Why this dataset matters​
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
