industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Product categories dataset
Product categories dataset for the Markdown & Promotions module, defining the hierarchical category structure used to group products for analysis.
The Product categories dataset defines the hierarchical classification used to group products in the Markdown & Promotions module. It supports category-level analysis and reporting across the product range.
This dataset acts as a reference dataset and is joined to the Products dataset using the product_category_id.
Purpose​
The Markdown & Promotions module uses the Product categories dataset to:
  • Group products into categories for aggregated analysis
  • Represent parent-child relationships between categories
  • Support reporting across product hierarchies
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_category_idUnique identifier for the product category.stringPrimary key
created_atTimestamp when the record was created.timestampNullable
metadataAdditional attributes or metadata, in JSON format.stringNullable
nameDisplay name of the category.stringNullable
parent_product_category_idReference to the parent category, for hierarchical structures.stringNullable
updated_atTimestamp when the record was last updated.timestampNullable
Usage notes​
  • Every category referenced by the Products dataset must exist in this dataset.
  • The parent_product_category_id should reference an existing category to form a valid hierarchy.
Why this dataset matters​
Consistent category definitions let the solution analyse markdown and promotion performance at the group level, not only for individual products.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
