industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
File formats and naming conventions
Supported file formats and naming conventions for file ingestion into Peak, including CSV formatting rules and compression recommendations.
This page lists the supported file formats and naming conventions for file ingestion.
Supported file formats​
Peak can ingest data from the following file formats:
There is no file size limit for uploads.
When possible, compress files with GZIP to reduce transfer size.
FormatNotes
CSVRecommended format for ingestion.
TXTMust use supported delimiters.
JSONSupported for file ingestion and feeds.
XMLRequires a root tag for parsing.
GZIPUse .gz or .gzip extensions when compressing files.
XLSXSupported if agreed in advance.
PDFSupported if agreed in advance.
CSV formatting rules​
When preparing CSV files for ingestion, follow these formatting guidelines:
  • Use comma, tab, or pipe as the delimiter.
  • Enclose all fields in double quotes.
  • Replace delimiter characters in data values where possible.
  • Use a header row for column names.
  • Use a single worksheet if exporting from Excel.
  • Use plain text character sets such as ASCII or UTF-8.
  • Use CRLF for new lines and remove stray CR or LF characters.
File naming rules​
Use these conventions when naming files for ingestion:
  • Use alphanumeric characters and the following special characters: ! - _ . * ' ( ).
  • Avoid # and + in file names.
  • Use lowercase file extensions.
  • Use a timestamp when files are part of a recurring feed.
Data extract guidelines​
Follow these best practices when extracting data for ingestion:
  • Use a unique identifier for each row when data is updated.
  • Keep date, datetime, and timestamp formats consistent.
  • Trim leading and trailing spaces from text fields.
  • Use incremental files after the initial load.
  • Peak does not handle record deletion by default.
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
