industry-department-solutions
- Overview
- Platform setup and administration
- Platform architecture
- Data Bridge onboarding overview
- Connecting a Peak-managed data lake
- Connecting a customer-managed data lake
- Creating an AWS IAM role for Data Bridge
- Connecting a Snowflake data warehouse
- Connecting a Redshift data warehouse (public connectivity)
- Connecting a Redshift data warehouse (private connectivity)
- Reauthorizing a Snowflake OAuth connection
- Using Snowflake with Peak
- SQL Explorer overview
- Roles and permissions
- User management
- Inventory management solution
- Commercial pricing solution
- Merchandising solution
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Application connectors
Configure application connectors to pull data from external platforms and services into Peak for analysis, including connectors for major APIs and web services.
Application connectors enable you to pull data from external platforms and services into Peak for analysis and decision-making. These connectors automate data ingestion from APIs and web services, eliminating the need for manual data exports.
Available application connectors
Peak supports the following application connectors for data ingestion:
- Google Ads - Import advertising campaign data, performance metrics, and conversion tracking.
- REST API - Connect to any REST-compliant API endpoint for custom data sources.
- Webhook - Receive real-time data pushes from external systems that support webhooks.
How application connectors work
All application connectors follow this standard configuration pattern:
- Authentication - Provide credentials or API keys to authorize Peak to access the external service.
- Configuration - Specify which data to import, including endpoints, filters, and parameters.
- Data mapping - Map external data fields to your Peak data schema.
- Scheduling - Set up automatic refresh schedules or trigger-based updates.
After configuration, Peak automatically ingests data according to your schedule, transforming it into the appropriate schema for use in your solutions.
