industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Product
product API resource for the B2B pricing application, with categorization and bespoke product indicators used in quote pricing scenarios.
Overview​
The product resource represents product entities in the B2B pricing application. This resource stores product information including categorization and bespoke product indicators.
→ For business context (purpose, usage notes, how this resource is used in the solution), see Products dataset in the User Guide.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PRODUCT{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) product records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product
  • updated_at (datetime) - Timestamp of when the record was last updated
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
product_idstringYesNoUnique identifier for each product. Used to join product metadata to quotations and sales for model training.
updated_atdatetimeYesYesTimestamp when the record was updated. Used to identify the most up-to-date data in the UI and to match product metadata to the date of each quote in model training.
product_namestringYesNoProduct name. Used in the UI to identify products.
bespoke_productbooleanYesYesWhether the product is bespoke (custom-made) or standard. Used in model training as a feature to determine the optimal quote price.
product_categorystringYesYesProduct category. Used in model training as a feature to determine the optimal quote price.
product_subcategorystringYesYesProduct sub-category. Used in model training as a feature to determine the optimal quote price.
Relationships​
Outbound References​
This resource has relationships to:
  • competitor_price - Products can have competitive pricing data
  • list_price - Products can have list prices across regions
  • product_cost - Products can have cost information
  • quote_line - Products can appear in quote line items
  • sale - Products can be sold
Inbound References​
None
JSON Representation​
  "solutionName": "QP_OOTB",
  "data": [
      "product_id": "PROD-001",
      "updated_at": "2025-01-28T10:00:00Z",
      "product_name": "Premium Widget",
      "bespoke_product": false,
      "product_category": "Electronics",
      "product_subcategory": "Components"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/QP_PRODUCT_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • Bespoke Products: The bespoke_product flag can be used to identify custom or made-to-order products
  • Custom Attributes: Custom attributes can be added with POST /api/v2/schema/{objectName}/add-attribute, where {objectName} is this table's fully qualified warehouse name ({prefix}PRODUCT{suffix} — for example, QP_PRODUCT_OOTB), as returned by Describe a solution's schema
  • Data Validation: All attributes are validated according to their defined data types
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
