industry-department-solutions
- Overview
- API Resources
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Purchase Order
purchase_order API resource representing purchase orders per product-location combination, tracking order details, delivery status, and fulfillment.
The purchase_order resource represents purchase orders for products at specific locations. This resource tracks order details, delivery status, and fulfillment information.
Resource Endpoint
/api/v2/ingest/object/{prefix}PURCHASE_ORDER{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) purchase order records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- order_number (string) - Unique order identifier
- product_id (string) - Foreign key reference to products
Attributes
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
| Attribute | Data Type | Required | Nullable | Description |
order_number | string | Yes | No | Unique order number (Primary Key) |
product_id | string | Yes | No | Product identifier (Primary Key, Foreign Key) |
location_id | string | Yes | No | Location identifier (Foreign Key) |
order_due_date_at | timestamp | Yes | No | When the order is due to be delivered |
ordered_at | timestamp | Yes | No | When the order was placed |
ordered_units | integer | Yes | No | Number of units ordered |
purchase_order_id | string | Yes | Yes | Alternative purchase order identifier |
status | string | Yes | Yes | Current status of the order |
delivered_units | integer | Yes | Yes | Number of units delivered |
receipted_units | integer | Yes | Yes | Number of units receipted/confirmed |
receipt_date | date | Yes | Yes | Date when goods were receipted |
actual_departure_at | timestamp | Yes | Yes | Actual departure timestamp |
expected_departure_at | timestamp | Yes | Yes | Expected departure timestamp |
created_at | timestamp | Yes | Yes | Timestamp when the record was created |
updated_at | timestamp | Yes | Yes | Timestamp when the record was last updated |
Relationships
Outbound References
None
Inbound References
- product - Foreign key
product_idreferences product - location - Foreign key
location_idreferences location
JSON Representation
"solutionName": "MP_OOTB",
"data": [
"order_number": "PO-2025-001",
"product_id": "PROD-001",
"location_id": "LOC-UK-001",
"order_due_date_at": "2025-02-15T00:00:00Z",
"ordered_at": "2025-01-20T10:30:00Z",
"ordered_units": 500,
"purchase_order_id": "PO-2025-001",
"status": "In Transit",
"delivered_units": 0,
"receipted_units": 0,
"receipt_date": null,
"actual_departure_at": "2025-01-22T08:00:00Z",
"expected_departure_at": "2025-01-21T08:00:00Z",
"created_at": "2025-01-20T10:30:00Z",
"updated_at": "2025-01-28T10:00:00Z"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/MP_PURCHASE_ORDER_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
- Foreign Key Dependencies: Can reference products and locations
- Order Tracking: Tracks the full lifecycle from order placement to receipt
- Fulfillment Status: Monitor ordered vs delivered vs receipted units
- Departure Tracking: Captures both expected and actual departure times
- Custom Attributes: Additional custom attributes can be added using the
/PURCHASE_ORDER/add-attributeendpoint - Data Validation: All attributes are validated according to their defined data types
